I just got powervcr and i'm trying to capture in both mpg 1 and 2. After recording for 30 seconds exactly, it will loop the last few seconds of the video while the audio keeps on playing. I've tried a lot of different profiles and none have worked. is there a setting I'm missing or something?
1 gighz athlon
640mb sdram
radeon 64mb ddr vivo
Did you also try to capture into AVI (not directly to MPG)?
If this results at the same way as you said before, check the performance of your system (IRQ's, DMA's, etc.). Some devices shares there resources but shouldn't when doing high-performance demanding tasks like capturing. Also be sure not to do anything else with your system when the capture is going on.
Recording 1080i 60 fields/sec vs 1080p 30 frames/sec
By johnnyquid in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 4th Apr 2011, 07:38 -
Powervcr II 3.0 Deluxe
By vijaye05 in forum Capturing and VCRReplies: 1Last Post: 7th Oct 2008, 05:30 -
12.0Mbit/sec MPEG-2 Capture?
By hech54 in forum Capturing and VCRReplies: 8Last Post: 1st Jan 2008, 19:40 -
System freezes while recording DVD-T
By gabier in forum DVB / IPTVReplies: 7Last Post: 23rd May 2007, 16:38 -
Padding out avi files to 25 frames per sec.
By yowie in forum Newbie / General discussionsReplies: 8Last Post: 12th May 2007, 09:52
