In this video:
https://youtu.be/F2tnTm0Z8Qg
The user says in the video description he used Virtual Dub with two nice filters to upscale the video. I really would like to know what plugin(s) he used. Maybe someone here knows? If you know, please let me know.
If you don't know exactly what the user used, it's okay. Does anyone know of any filter(s) that I could use in Virtual Dub that could upscale video to achieve the same results as the video I noted above?
You lucky may vary with super resolution plugin, we had a recent discussion about SD to HD conversion and from my tests with SR looks like garbage and if you try to use some other filters to smooth it out the noise SR add to the video you'll loose details even if you try to sharpen the result latter.
For sharpening looks like he used some kind of Unsharpen Mask tool, avisynth has WarpSharp/UnsharpMask and UnsharpHQ, unsharpen tools give a better end result than a simple sharpen tool.
video into Virtual Dub
By lovebug in forum Newbie / General discussionsReplies: 2Last Post: 2nd Oct 2017, 07:25 -
AVISynth and virtual dub
By martin. in forum Video ConversionReplies: 7Last Post: 7th May 2016, 03:38 -
Doing fades in virtual dub.
By jwtweeg in forum EditingReplies: 10Last Post: 24th Jan 2016, 23:23 -
BD-Rebuilder: To upscale or not to upscale, that is the question.
By hbenthow in forum Authoring (Blu-ray)Replies: 7Last Post: 15th Dec 2015, 14:19 -
Need 5.1 encoders for virtual dub
By Artas1984 in forum Video ConversionReplies: 5Last Post: 20th Oct 2014, 13:56
