Here are three possibilities:
1. Anything on a larger monitor looks blurrier;
2. You need to check the resolution setting (lower right corner of the YouTube screen) when playing on your computer's monitor. Sometimes they only deliver 480p, even if the video is 1080p, and you need to manually change that.
3. You were not clear on this, but if you are watching on the external monitor, and you are watching from the laptop, you may not have the external monitor settings configured correctly. It is VERY important to get those settings so that the scaling is done correctly. I presume you have the video driver set to deliver video to the laptop's own screen at its "native" resolution. The external monitor is almost certainly not the same resolution as your laptop's screen and if you deliver the laptop's resolution to the external screen, the video quality will suffer tremendously.
How to use PC as a realtime video monitor
By The Lee in forum Newbie / General discussionsReplies: 8Last Post: 30th Jun 2015, 13:23 -
Video changes blacklevels when move to another monitor
By newpball in forum ComputerReplies: 4Last Post: 11th Jan 2015, 19:21 -
Control PotPlayer on Monitor 1 play video on Monitor 2
By CyberDude4819 in forum Software PlayingReplies: 4Last Post: 5th Dec 2014, 11:16 -
Video that views fine in VLC - appears cropped in Premiere Pro/other suites
By supersi in forum Video ConversionReplies: 1Last Post: 10th Oct 2014, 00:15 -
New monitor for Photoshop/Video editing????
By rivrbyte in forum Newbie / General discussionsReplies: 17Last Post: 8th Mar 2014, 13:54
