What is the newest Dazzle USB capture device works with Windows 10 and VDub and PAL/NTSC? There are black ones and white ones but Pinnacle doesn't say what's the difference between them or which is older and which is newer. And off course they will not answer this question because they want you to use their crappy software.
Results 1 to 1 of 1
Can a 480p capture device capture 640x480 well? Seeking a suitable device
By Neil-Betamax in forum Newbie / General discussionsReplies: 28Last Post: 21st Apr 2020, 10:56 -
Out of touch with video capture - USB capture device advice
By Lambchop in forum Capturing and VCRReplies: 7Last Post: 25th Nov 2018, 05:19 -
1080p 60fps mp4 capture device...that uses device CPU not PCs CPU?
By Blackout in forum Capturing and VCRReplies: 36Last Post: 11th Sep 2018, 13:40 -
Studio 19 Dazzle Capture
By KBos in forum Capturing and VCRReplies: 0Last Post: 11th Apr 2017, 14:09 -
I am looking for a capture device that will capture widescreen format
By zinctrumpet in forum MacReplies: 10Last Post: 3rd Nov 2015, 14:16
