Hi all, I'm trying to open m2ts video file on Virtualdub. I have installed and downloaded FccHandler mpeg2 Input Driver and DirectShow Plugin. But I still have a problem. Can anyone explain how to do it as people did in the past?
Results 1 to 14 of 14
Why don't you just use Virtualdub2 as was suggested. It has it's own decoding, no need to worry about ffdshow.
Are you using Windows xp? -
I tried using VirtualDub2, but the message popped out saying this video editor is unknown software and that opening it can infect computer with virus. I'm just afraid of it.
Download it from this forum
https://www.videohelp.com/software/VirtualDub2
it's clean, it's actively developed, the author is a member and contributes to this forum -
Thanks. I'll try using it. Can you tell me what's the difference between VirtualDub and VirtualDub2?
[Attachment 48283 - Click to enlarge]As shown on the screenshot, it doesn't let me open VirtualDub 2 -
Thanks. It's working and all compression codecs are already in it. I found there's also FFDSHOW compression. When I clicked it, it popped up video encoder configuration and video processor configuration. In video processor configuration, it shows many filters. I'm considering using it for cropping my video because virtualdub cropping filter is not that accurate because it's not very flexible with unit. When I checked filters in video processor configuration, nothing happened. Can you tell me what should I do with this?
Use the Virtualdub resize. If you want a free hand, choose absolute pixels, disable aspect ratio and for codec friendly
resizing, choose multiples of 2 (multiples of 4 may work better with some codecs, you'll have to try it and see)
are you using XP? If not, I'd uninstall FFdshow/haali splitter and use LAV filters
Is the VirtualDub FilterMod better than VirtualDub?
By ResetMaster in forum Video ConversionReplies: 26Last Post: 2nd Jul 2017, 14:08 -
VirtualDub Please Help Me!
By DylanCs in forum Video ConversionReplies: 10Last Post: 7th Jun 2016, 09:42 -
Virtualdub
By glenpinn in forum EditingReplies: 11Last Post: 27th Mar 2016, 13:04 -
Virtualdub ERROR CODE 512 ACMERR_NOTPOSSIBLE - DivX to Xvid in Virtualdub
By kurtky in forum Video ConversionReplies: 6Last Post: 4th May 2015, 13:26 -
virtualdub help
By erzane in forum Newbie / General discussionsReplies: 4Last Post: 12th Aug 2014, 07:23
