Why won't my dvd clips import on to resove. stil photos will
Results 1 to 9 of 9
Unless you have some plugin(s) or did some intermediate conversion THAT YOU AREN'T TELLING US ABOUT, that is the problem.
The only mpeg2 video that is supported by Resolve is in an mts (transport stream) container.
Dvd is mpeg2 (or mpeg1) in a vob container, or if re-wrapped - in an mpg ps (program stream) container, or if demuxed - as raw m2v stream, and none of those are supported by Resolve as it normally comes.
Scott -
Oh yeah, I skipped xdcam. Wasn't going to go there, as most consumers don't know what that is but then neither would they need to worry about it. Same with all the MXF stuff.
ScottLast edited by Cornucopia; 24th Feb 2019 at 10:21.
Why then do's it say it supports it. If it dos'nt support it how then are you then able to use this program or is it only for professionals
Where are you seeing that DVD is supported? That's not on BlackMagic's site.
Please provide a link. -
It supports "DV”, as in the 90s I-frame tape capture consumer video format,
not “DVD”, the GOP-based MPEG2 authored consumer disc distribution format.
BIG difference.
Converting with old PC, which program better?
By GreyAlex in forum Newbie / General discussionsReplies: 7Last Post: 13th Mar 2019, 15:23 -
Program Type help
By biferi in forum EditingReplies: 1Last Post: 18th Nov 2018, 16:38 -
what is the program ?
By petra0edit in forum EditingReplies: 4Last Post: 7th May 2017, 01:00 -
One program to convert all to all.
By fits79 in forum EditingReplies: 11Last Post: 1st Jan 2017, 15:31 -
Any hardsub program?
By ricesniffer in forum SubtitleReplies: 7Last Post: 8th Aug 2014, 07:05
