  1. lets say there are bd rips that i make , i want to make them as small as possible while retaining the best quality, without minimal detail lose and without blurriness from low bit rate.
    lets say i make them 720p when i rip them (in anime there is mostly no detail lose when going from the bd to hd) , and use HEVC format , constant bitrate.
    here is a big file i made for the sake of "preserving the detail" and testing.
    Format                                   : HEVC
    Format/Info                              : High Efficiency Video Coding
    Format profile                           : Main@L3.1@Main
    Codec ID                                 : V_MPEGH/ISO/HEVC
    Duration                                 : 29mn 14s
    Bit rate                                 : 3 980 Kbps
    Width                                    : 1 280 pixels
    Height                                   : 720 pixels
    Frame rate mode                          : Constant
    Frame rate                               : 23.976 (24000/1001) fps
    Bits/(Pixel*Frame)                       : 0.180
    Stream size                              : 832 MiB (95%)
    could the 20-30 min ep be made into 100-150 mb HEVC file and look almost identical?
    since its anime , lose of detail is a bit different from movies.
  2. Impossible to answer in generic terms.
    It depends on the type of anime , how compressible it is . And your tolerance for quality loss -what might be "acceptable" loss for you, might not be for someone else
    It's not very helpful, but you have to do some tests and see if it's good enough for you
  3. Originally Posted by poisondeathray View Post
    understandable , just ran a small sample trough handbrake (god this program is terrible) , came out almost the same at 800kbps , beside the problems the program itself (or me from not knowing how to use it) like jagged lines.
  4. Originally Posted by zanzar View Post
    understandable , just ran a small sample trough handbrake (god this program is terrible) , came out almost the same at 800kbps , besite the problems the program itself (or me from not knowing how to use it) like jagged lines.
    But "jagged lines" could easily be user error, or wrong settings in handbrake . eg. it could be not handling source properly eg. deinterlacing instead of IVTCing, might be resizing interlaced material incorrectly etc...
    If you don't like handbrake, try something else, maybe staxrip, megui, hybrid, etc... many GUI's to choose from
  5. Originally Posted by poisondeathray View Post
    yeah i know i dont really use it , i just grabbed it for a quick test, also any rec' of encoding program to use with vapoursynth?
  6. Originally Posted by zanzar View Post
    I think staxrip, hybrid support vapoursynth. I don't use the GUI's , I just use commandline tools directly
    Consider using 10bit ,especially for anime . Helps with banding , better compression ratio in the low to medium bitrate ranges. (Worse at very low bitrates, however) . But if you're aiming to "preserving the detail", that suggests to me using decent bitrates
    Nov 2018
    Germany
    Do not use constant bitrate, ever. Its compression efficiency is vastly inferior to 2-pass VBR or CRF, so there is absolutely no reason to use it if you don’t have to. I suggest using CRF mode with a value of ~17 with x265 if you want your encode to be near indistuinguishable from your source. CRF mode will adapt to the type of content and will adjust the bitrate such that a constat level of quality is maintained. This will also result in wildly different bitrates, as different types of anime content require wildy different bitrate (e.g. high-motion scenes with a lot of high-frequency detail such as fine grain will consume multiples of the bitrate a regular talking scene or panning shots need). If your priority is file size, you should use as slow a preset as you can since that will generally improve compression efficiency.
