Trying to capture VHS tapes...some of them are ok,some have partially distortions/jumpings on the screen.
Have cleaned heads, tapes but the effect is similar on both VHS players Iīve tried.
Is there any way to rid of those things? How? Should I ev.look for any other players?
What causes that issue?
Attaching AVI few secs vid.
Any help appreciates-donīt want to go too much of a work before problem is fixed.
Results 1 to 9 of 9
You have been a member since 2014 yet I fail to understand that you do not (apparently) understand about Time Base Correction (TBC).
First of all-to be member certain time doesnīt mean you participate in forum every day constantly.
Secondly-I wanted to be sure that this is TBC issue,thatīs why my question.
So reasuming-such error will occur all the time as long as I run tapes on average vhs player,yes?
The only solution is trying find a player with TBC function? Not many such machines on the market... -
This artifact is called flagging and indicates a tension problem on recording or playback, or possibly physical shrinkage of the tape. Wind the tape-end-to-end a couple of times to retension it. A TBC would most likely fix it, for example a Panasonic DMR ES-10 or ES-15 or a DataVideo TBC-1000.
I did rewinded tapes many times but some issues stand still. Seems like all those devices with TBC function are quite unik and very expensive.
I just simply donīt want make any mistakes as it happened to my friend. She has sent few tapes to "professional" company she found on the net. They made convertion but obviously did not consider very much about TBC,since many of her family films look approx. like mine in this attached clip. I simply donīt think they made good job! Today anybody can convert vhs to digital but good vhs player is a must.
With one word- so there are no players today what can do the job properly exept old machines. Iīm trying to understand why is that so if technics improve all the time but some problems canīt be solved today. -
Not all conversion businesses know what they are doing, Most of them are just doing it for a quick buck with a $20 VCR and a Chinese easycap, If the price is so cheap chances are you are dealing with one of those guys.
Thank you guys for replies.
@JVRaines...I live in Europe so all VCRs u mentioned are probably not actual for me.I need PAL system.
So the only option is those I presume:
Panasonic AG-1980 (NTSC) = NV-FS200 (PAL)
Panasonic NV-HS1000 (PAL)
Panasonic NV-HS950 (PAL)
A bit expensive but it can be worth every penny.
Canīt find any other models which would correspond to job they should do.
Is it any differencies between them-from that POV- will they do proper job no matter which I get lucky to purchase? -
vhs/easycap - jumping image
By incanto in forum Capturing and VCRReplies: 24Last Post: 31st Oct 2017, 08:21 -
Aegisub: Whole line jumping
By PetitKero in forum SubtitleReplies: 2Last Post: 28th Jul 2017, 15:08 -
Jumping picture
By Mr Chris in forum Newbie / General discussionsReplies: 4Last Post: 19th Dec 2015, 13:34 -
.TS files jumping after authoring with MultiAVCHD/TSMUXER
By digitalfreaknyc in forum Authoring (Blu-ray)Replies: 8Last Post: 24th Jun 2015, 18:57 -
MPC-HC Hangs when jumping forward
By vhwul62 in forum Software PlayingReplies: 8Last Post: 7th Feb 2015, 18:05
