I know how to rip a Blu-ray to my PC but how do i get the subtitles with it? All the guides i find are way over complicated. I'm trying to do this for TV shows not a movie.
For example i rip the big bang theory with makemkv fire up videocoder/handbrake they see the subtitles and can put it into a MP4 file but you can not turn them on/off with vlc player, i think it's burned to the video.
Is there something i'm missing?
Thanks for the help!
With OCR: Try to open the mkv created by MakeMKV with Subtitle Edit, then do the OCR and export to .srt. Add the .srt into HandBrake when re-encoding (untick "burn-in").
Faster without OCR: re-encode using from the MakeMKV mkv using HandBrake without any subtitles. Then use MKVToolNix GUI to open both MakeMKV mkv and HandBrake mkv/mp4 and select HandBrake video+audio but MakeMKV subtitle (i.e. untick the tracks you don't need). Then you can turn them on/off in VLC.
(For some reason HandBrake seems to only support burn-in if you open PGS-in-MKV.)Last edited by sneaker; 20th Feb 2019 at 15:44.
Alternatively to OCR one can also use BDSup2Sup++ to convert the subtitle to idx/sub subtitles.
users currently on my ignore list: deadrats, Stears555, marcorocchini -
MP4 output + BITMAP subtitles = You are not going to be happy
Realistic Options:
1. Use MKV output container.
2. Burn them into the video (MP4 output container), permanently.
3. Search and download TEXT based subtitles.
4. OCR the subtitles to text.
5. Make a subtitle file from scratch
As a side note, since I have not problem with mp4 and idx/subs, if you have a mkv file with mp4 audio&video in it and pgs subtitles you can use Hybrid to remux to mp4 and at the same time convert the subtitles from pgs to idx/sub.
Here's how that can be done:- Start Hybrid.
- Set default paths. (Config->Paths)
- Tell Hybrid to passthrough subtitles. (Config->Automation->Passthrough streams)
- Set audio&video to passthrough. ('Base->Processing->Video->passthrough','Base->Processing->audio->passthrough (all)')
- Enable automatic output name generation. ('Base->Generate')
- Load the source file. ('Base->Open file')
- Create a new entry into the 'Job-Queue'. ('Base->Add to queue'
- Start processing ('Jobs->Queue->Start')
Especially older devices (and software players) might not support mp4s with idx/sub subtitles, for me all my devices support it so it's a solution for me, but it might not be for you.
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
I was looking for something for SUP->SRT conversion and found this thread.
1. Subtitle Edit is just bad -- slow and bizarre recognition errors. Additionally, it inserts a negative offset for the first line when exporting. I don't recommend it.
2. SupRip 1.16 -- quickly and accurately OCRs SUP subtitles and saves them to SRT. The only downside is that at the beginning, you have to help it recognize fonts once and confirm each one.
How to backup and convert Blu-ray to MP4 HD or MKV HD
By Baldrick in forum User guidesReplies: 360Last Post: 13th Nov 2017, 00:51 -
Blu Ray Iso to MP4 With out Quality Loss
By rustyrankin in forum Blu-ray RippingReplies: 28Last Post: 14th Jul 2016, 01:25 -
Converting Blu-ray to MP4 and MKV, actually free
By zanthal in forum Blu-ray RippingReplies: 1Last Post: 30th Dec 2015, 00:15 -
HQ Mp4's To Blu Ray?
By Gimmick4Life in forum Blu-ray RippingReplies: 2Last Post: 6th Jul 2015, 02:49 -
splitting blu ray mp4
By Anonymous2 in forum Video ConversionReplies: 6Last Post: 22nd Feb 2014, 15:49
