Hello!
I've file encoded with x264 with parameters:
But MediaInfo shows some strange thing:Code:--profile main --level 3.1 --bluray-compat --preset veryslow --tune film --crf 24.0 --ref 2 --slices 4 --qpmin 3 --vbv-bufsize 14000 --vbv-maxrate 14000 --colorprim bt709 --transfer bt709 --colormatrix bt709 --sar 1:1
As you can see in "Format settings", "Format settings, ReFrames" shows that there is actually 3 ref ReFrames, but "Encoding settings" shows that parameter "ref" was set to "2"... where is the truth? =) Why it shows that?Code:Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L3.1 Format settings : CABAC / 3 Ref Frames Format settings, CABAC : Yes Format settings, ReFrames : 3 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 2 h 58 min Bit rate mode : Variable Bit rate : 2 548 kb/s Maximum bit rate : 14.0 Mb/s Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.115 Stream size : 3.17 GiB (100%) Writing library : x264 core 157 r2935 545de2f Encoding settings : cabac=1 / ref=2 / deblock=1:-1:-1 / analyse=0x1:0x131 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=6 / lookahead_threads=1 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=1 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=1 / keyint=240 / keyint_min=1 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=24.0 / qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / vbv_maxrate=14000 / vbv_bufsize=14000 / crf_max=0.0 / nal_hrd=vbr / filler=0 / ip_ratio=1.40 / aq=1:1.00 Encoded date : UTC 2019-02-18 00:11:30 Tagged date : UTC 2019-02-18 00:15:06 Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709
And even if I encode with manually set "ref" to "3"... MediaInfo do not shows that "Format settings", "Format settings, ReFrames" set to 4... in that situation all string reports that "ref" was set to "3"
I believe the size of the reference frames storage is increased by 1 when the B frame pyramid is enabled...
Why x264 "placebo" preset produce bigger file than "very slow"?
By aleaksunder in forum Video ConversionReplies: 21Last Post: 2nd Mar 2019, 07:25 -
mediaInfo says using AAC [instead of AC3] bitrate becomes alwais "variable"
By marcorocchini in forum Newbie / General discussionsReplies: 13Last Post: 18th Feb 2019, 01:58 -
x264 & FFmpeg: "64-bit dictatorship"?
By bulgom in forum Video ConversionReplies: 39Last Post: 5th Oct 2018, 00:13 -
x264 from videolan "releasing zombie picture" ?
By hydra3333 in forum Video ConversionReplies: 1Last Post: 30th Aug 2015, 08:41 -
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 07:21
