Anyone happen to experience quality loss when it comes to convert MKV to DVD using DVDStyler or does it also happen with other video format. I tried it one time with a PAL VHS recording that's in .mpg format and I didn't see any differences comparing to the original .mpg and the DVD files.
If the .mpg file was already dvd compliant then it may well have just gone through DVDStyler without any re-encoding. Your .mkv file is probably not DVD compliant and is therefore being re-encoded with whatever default settings DVDStyler uses. On the few occasions I've used DVDStyler, I've always made sure that I'm giving it video that it doesn't need to do anything to before authoring it to DVD. As flashandpan007 said, a MediaInfo log would be helpful. (Just to clarify for the uber-picky - like me sometimes! - I know that DVDStyler will author mpeg files that are not strictly speaking DVD compliant - mpeg2 with a resolution of 544x576 pixels, for example - it shouldn't author an h.264 .mkv file without doing some form of conversion/transcoding first. I think.)
It's already DVD-compliant. You don't even have to reencode. It also says it's an MPG, not an MKV.
If this is really the 'original'.Last edited by manono; 21st Feb 2019 at 00:53.
BluRay to .MKV - is there a loss in quality?
By Carotis_Interna in forum Authoring (Blu-ray)Replies: 4Last Post: 18th Oct 2018, 16:11 -
I need a software that watermark without quality loss
By imsrk48 in forum EditingReplies: 6Last Post: 8th Oct 2017, 07:56 -
Minimizing quality loss?
By xtreme1699 in forum Video ConversionReplies: 16Last Post: 13th Jul 2015, 02:59 -
Combine 2 MKVs without Quality Loss -- Please
By DarkPhoenix77 in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jun 2015, 15:53 -
Edit mpeg-2 > quality loss ??
By Surfdude1982 in forum EditingReplies: 8Last Post: 5th May 2015, 03:47
