Hi, but I'm a cat
please can you tell me what is a good screen recorder alternative to bandicam?
thanks
komersonGuest
there are so many options, some are free like obs, freecam, some are paid ones like RecMaster, moviva etc. If you just use it for once, you may try free ones, but if you use screen recorder daily, i suggest you use those paid ones(choose the best one you like and fulfill your needs). Paid ones are usually better than free ones from my point of view.
Cant record full screen games with bandicam?
By supercain in forum Software PlayingReplies: 6Last Post: 7th Dec 2015, 05:31 -
[SOLVED] ZD Soft Screen Recorder
By suadnovic in forum Capturing and VCRReplies: 10Last Post: 27th Aug 2015, 23:31 -
Screen capture with Bandicam and Largarith lossless codec as 60fps.Convert?
By SyncroScales in forum Video ConversionReplies: 6Last Post: 24th Jul 2015, 09:40 -
Pinnacle Dazzle DVD Recorder DVC 101 alternative software
By Cazz in forum Capturing and VCRReplies: 4Last Post: 1st Jul 2014, 21:26 -
Help with settings (Bandicam)
By u222683 in forum Video Streaming DownloadingReplies: 6Last Post: 7th May 2014, 21:30
