  1. Hello guys!
    I would like to know if there's a way to use the 64bit plugins from avisynth inside vapoursynth script with the Eval function.
    I know that it is possible to directly open 64bit avisynth plugins in vapoursynth using the LoadPlugin function, but, problems usually occur with deinterlace filters using this method, problems that don't happen using Eval.
    Attached image with error when I tried to use the TFM() filter
Name:	VS Problem.PNG
  2. If you have those DLL's in Avisynth plugin folder , it does not have to be included in actual script. That does not work with avsw.Eval?
  3. for example this would work:
    file = r'C:/files/DV.avi'
    import vapoursynth as vs
    clip = vs.core.avisource.AVISource(file)
    clip = vs.core.avsw.Eval(
        'AssumeBFF()'
        'QTGMC(Preset="slow")'
        'LanczosResize(640,480)',  #just make sure there is comma after last line of your avisynth script but not any above
        clips=[clip], clip_names=["last"])
    clip.set_output()
    where DLL's are in Avisynth plugin folder
  4. Originally Posted by _Al_ View Post
    I think there's some misunderstanding, the Eval function works, but it uses the 32bits plugins from avisynth and I want to use the 64bits plugins, loading the plugin directly into the vapoursynth script gets very slow and returns the error of the attached image in the first post.
    Example:
    It works fine
    core = vs.get_core()
    src = core.d2v.Source(r"D:\Title2.d2v")
    deinter = core.avsw.Eval('AssumeTFF() TFM(mode=6, PP=0, chroma=false) TDecimate(mode=1, hybrid=0) ', clips=[src], clip_names=["last"])
    deinter.set_output()
    It works very slow and returns the error mentioned above
    core.avs.LoadPlugin(path=r"C:\Program Files (x86)\AviSynth+\plugins64+\TIVTC.dll")
    tfm = core.avs.TFM(src)
    tfm.set_output()
