Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. I have a 5.1 audio that was converted to 6 mono WAV files that I'm using for Premiere Pro. From what I believe, I used solo one of the tracks where besides some heavy bass parts its just room temp noise and I think I saved it. But the software started lagging and I was unable to get any sound at all including the bars not going up. I closed it then opened it again and I still have the same problem even when I add a new audio clip on either track.
    Oct 2005
    666th portal
    so what's the question???
  3. How can I get the audio/sound back. It doesn't come back no matter what I try.
    Oct 2005
    666th portal
    have you considered that if pp says there is no audio that it is correct???? you messed something up and should try a different way.
