Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
Results 1 to 16 of 16
  1. Hi there (sorry for my english)
    here is my problem :
    I have a movie on mkv (video /french language) but as it is a japanese movie i prefered the video quality of the blu-ray ripp with the original japanese language (from the dvd i bought).
    so i extracted the audio from my dvd, and added it on the mkv.
    there is a big delay.
    the dvd and mkv movie seems same time on the video but when i looked at the last for each audio files i have the one from the MKV last 2h15min the one from the dvd last 2h10...
    so the question is : is this delay is from a setting to do somewhere (or problem of bitrate differences with blu-ray and dvd?) or the mkv is longer version and the dvd normal version maybe?
    any idea where the problem can come from?
    thanks
    genesian
  2. If they start in-sync but gradually divert it could be a symptom of PAL-Speedup.
    So you either speed up the video fps to 25 fps (e.g. using mkvtoolnix) or slow down the audio (e.g. using eac3to "SOURCE" "OUTPUT" -25.000 -changeTo23.976).
  3. ok thanks i'll try that
  4. do i n eed to speed up the mkv video before adding my audio from dvd or it's not effect on the sound?
  5. Originally Posted by sneaker View Post
    do i need to speed up the mkv video before adding my audio from dvd or it's not effect on the sound?
  6. If you change video fps in mkvtoolnix it doesn't affect the audio. So you can change video fps and add additional audio in a single step.
  7. Originally Posted by sneaker View Post
    i did what u said it's really better but still a small delay the video is a bit soon compared to the audio but it's regular during all the movie it seems...
    i'll try to see in VLC the delay. eac3to seems hard to use (cmd command)
  8. i have a -0.800s delay in audio/video sync in VLC
  9. Enter that as delay for the audio track in MKVToolNix GUI, mux again, and hopefully everything will be fine.
  10. Originally Posted by sneaker View Post
    i tried to put -0.800 but it didn't want to mux (or demux? ) i tried 0,800 instead of a point...i'll see if it works
    EDIT : didn't have sound anymore lol
    and the last of the movie instead of 2h14min52 sec is 1735h58 and 17s lol
  11. MKVToolNix GUI expects milliseconds. Try "-800".
  12. Originally Posted by sneaker View Post
    yes i thought the same, so i checked in vlc and it's in seconds so i tried -800. i'll check the final result
  13. Originally Posted by sneaker View Post
    yipikaaaiii it works thank you very much
    now another question i think i can add subtitles in this movie via mkvtoolnix right? in wich format? .srt? .ssa?
  14. Mkvtoolnix supports a variety of subtitle formats, among them srt, ass/ssa, idx/sub (DVD), sup (Blu-Ray).
  15. damn my french language wich was well set at the beginning now is delay lol and the japanese is good. i tried to find the delay in vlc but it's more than 42.500 and when i go to far in delay in vlc i don't have sound anymore...
    i'll think i'll do two files one with french for mu brother who don't like subtitles and one for me...the harder will be to do all the subtitles in french lol
    thanks for your help and time u took to answer me
  16. Well, you didn't say you want Japanese and French.
    Of course if you make the video faster but the French audio stays the same they don't match each other anymore.
    There is a quick but ugly "fix" for this using mkvtoolnix. I don't rrecommend it but in MKVToolNix GUI select the French audio and enter "24000/25025" into its "Stretch by" field (between delay and fps setting). Using eac3to is better.
