Hey
I ripped my Dragon Box (Dragon Ball Z) collection a while ago and I want preserve the grain as much as possible, but I'm not sure which tune to use, if at all. "Animation" removes too much grain. "None", "Film" and "Grain" work better, though, "Grain" seems to enhance the grain than preserve it and doesn't look right to me.
It's not your typical anime source, but it's also not real footage with grain either, so I'm not really sure which one to use.
Results 1 to 10 of 10
Make sure psy_rd is at least 1. That will affect grain preservation the most. I’ve seen some DB encodes push it to 1.15, but that seems like overkill.
If you’re looking for a tune to use I would just go with “film”. I know there’s an “animation” tune, but that uses several assumptions about the source video that are not true in this case.
--preset slow
--tune film
--aq-strength 1.8 or so.
Keep in mind that retaining grain is very expensive in terms of bitrate. -
Haha, yeah, I have done a few encodes with ABR at 1000 kbps and ABR at 2000 kbps (so that I can compare the impact of the x264 tunes at the same bitrate), and it's clear that not even Grain or Film can preserve enough grain with ABR at 1000 kbps. No free lunch!
And thanks, Film with aq-strength at 1.8 got very close to the source in terms of grain. If aq-strength is important for retaining grain, why is it set low in the "Grain" tune?
Should I leave psy_rd and psy_trellis at their defaults for Film? -
You can go even higher with aq-strength to retain even more grain. I found 1.8 was enough to prevent posterization in some difficult shots I was working with.
aq-strength is lowered with grain preset because it redistributes bits from edges . If you don't encode with adequate bitrate , you will get halos of reduced grain around object edges, and frame edges, instead of a more uniform distribution. It's ugly and one of the major side effects of AQ with grain (or any type of noise ). On cleaner animation sources, AQ still takes away from edges, so the drawn lines become less clear (that's why it's also reduced with animation preset). But higher bitrates trump everything. If you used crf, AQ will actually increase bitrate everywhere, but still disproportionally redistributes from edges to flat, darker areas . But if you're using 2pass, or 1pass ABR, it still redistributes in the same manner, but instead of the bitrate ballooning up, you will get those ugly artifacts when you restrict to insufficient bitrate ranges
Grain retention requires some psy_rd, psy_trellis. You can start with the film or grain defaults . But you might have to tweak the values to get exactly what you want.
Look for areas of spotchy grain too . That's usually the first indication that you're not using enough bitrate. -
Thanks for explaining this stuff to me
If you don't mind having a look, I have done a few encodes with ABR at 1500kbps:
ABR1500 Film: https://files.videohelp.com/u/246075/ABR1500%20Film.mkv
ABR1500 Grain: https://files.videohelp.com/u/246075/ABR1500%20Grain.mkv
ABR1500 Film (aq_strength=1.8): https://files.videohelp.com/u/246075/ABR1500%20Film%20AQ_1.8.mkv
Source: https://files.videohelp.com/u/246075/Source.mkv
At 1000 kbps, the grain looks a bit splotchy, but at 1500 kbps it looks okay to me. Just wondering what you guys think
4K to x264 settings
By hatenooobs in forum Video ConversionReplies: 6Last Post: 12th Mar 2018, 03:13 -
Megui settings for anime?
By qnkov in forum Video ConversionReplies: 4Last Post: 17th Apr 2017, 08:28 -
Should i encode anime DVDrips in x265 or stick to x264?
By zanzar in forum Newbie / General discussionsReplies: 1Last Post: 13th Sep 2016, 15:37 -
x264 Mediainfo to MeGUI x264 Settings
By Arugen in forum Video ConversionReplies: 2Last Post: 13th Aug 2015, 02:14 -
Best Megui settings for anime?
By qnkov in forum Video ConversionReplies: 3Last Post: 3rd Apr 2015, 03:26
