I have a brand new 4k Brio Logitech webcam (currently the most expensive model they make). I have it set up in my office, which is quite small, so lighting is easily controlled. I have a bright overhead light with a daylight bulb, as well as a desk lamp pointed directly at my face (also with a daylight bulb), all of which are lit for my streaming setup.
While I get a pretty nice image quality over all from this cam, the video noise is quite prevalent. I've read this is usually due to low lighting conditions, but obviously that's not the case here. I have attached a gif of the back of my chair, which illustrates the graininess.
Is there a way to fix that either with my setup, my cam settings or maybe a filter in a program for OBS Studio? In After Effects or Premiere, I'd just apply a noise filter and it would smooth it right out. However, I have to do that in real time here.
Thanks (GIF below)
Ideal FPS - Low Light - GoPro?
By jaebird82 in forum Newbie / General discussionsReplies: 11Last Post: 4th May 2017, 13:37 -
easy way to fix a low light video recording
By paleskin in forum Newbie / General discussionsReplies: 5Last Post: 20th Mar 2017, 08:13 -
Most revealing editor render quality evaluation - low light noisy photage?
By larioso in forum EditingReplies: 3Last Post: 17th Jan 2017, 08:36 -
Which camcorder has the bigger sensor and better low light performance?
By abeelandig in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Nov 2016, 11:32 -
ffmpeg noise filter usage based on mplayer noise settings?
By Selur in forum Video ConversionReplies: 5Last Post: 21st Jun 2015, 09:19
