Hi,
There is a way to capture/save/stream live video to some big data storage?
thanks,
Don't get me wrong but my crystal ball is broken...
Provide details as many as you can. Describe your issue in a proper way to make possible to help you...
Informational - my feedback was based on fact that every transmission can be captured, stored and streamed... bits are only bits - depends on real life limitations this may be just unpractical. -
it's an HDV cam. connect the firewire cable to the computer, turn on the camera. start hdvsplit and set the record directory up to where you want the video recorded to. click record on the hdvsplit menu. it's 13GB/hour.
Best data backup procedures, media and storage
By lingyi in forum Newbie / General discussionsReplies: 0Last Post: 17th Dec 2018, 22:56 -
If do not watch 4k hdr content, is it still worth buying a 4k hdr display o
By Stealth3si in forum Media Center PC / MediaCentersReplies: 5Last Post: 19th Sep 2016, 21:03 -
Premiere Pro CS6 Capturing MP3 Only on HDR-HC1
By maxruddock12 in forum Capturing and VCRReplies: 25Last Post: 20th Jun 2015, 05:17 -
home small data storage center???
By kenny1999 in forum ComputerReplies: 10Last Post: 8th Feb 2015, 21:22 -
How to capture video chunks frames of data in realtime from HVR 2250?
By rshapiro in forum Capturing and VCRReplies: 19Last Post: 27th Aug 2014, 06:41
