Hello
I have hundreds of videos and I want to extract the FPS of each one to a text file, or an excel, or anything that I can work with.
How would I go about doing this?
I'm sensing I'll need to use ffmpeg command line along with a batch script or something, but I'm not that good with either.
Thanks in advance
I have managed to find this
and it worksCode:ffprobe -v 0 -of csv=p=0 -select_streams v:0 -show_entries stream=r_frame_rate filename.mp4
but how do i go about automating for all files in a specific folder
AND
to export them to a .txt file/table anything
Put a batch file like this in the folder:
That will create a file called fpslist.txt with:Code:del fpslist.txt for %%F in (*.mp4) do ( echo %%F >>fpslist.txt "g:\program files\ffmpeg\bin\ffprobe.exe" -v 1 -of csv=p=0 -select_streams v:0 -show_entries stream=r_frame_rate "%%F" >>fpslist.txt ) pause
Note: You'll need to change the path to ffprobe.exe.Code:filename1.mp4 25/1 filename2.mp4 30000/1001
If you want the name and fps on the same line replace the echo line with:
Code:echo | set /p="%%F " >>fpslist.txt
Convert multiple video files to multiple DVD ISOs
By tons of guns in forum Video ConversionReplies: 1Last Post: 14th Jul 2017, 19:52 -
Extracting only audio from BD files on HD
By carlmart in forum Blu-ray RippingReplies: 4Last Post: 22nd Jun 2016, 12:40 -
Tool for Multiple Frame Rates to 24 fps
By ensignrickyto in forum Video ConversionReplies: 3Last Post: 16th Sep 2015, 10:02 -
Extracting multiple audio streams from MXF
By nesburf in forum AudioReplies: 4Last Post: 8th Jun 2015, 17:51 -
FFMPEG - How to record multiple RTMP streams into multiple files
By wwwmaster2k in forum Capturing and VCRReplies: 1Last Post: 11th Jul 2014, 12:51
