Trying to split an mkv with solveigmm. Says Unable to render audio. Necesary codecs not found.. Media info says Format Opus
Codec ID : A_OPUS
I downloaded opus but how do i install it
http://opus-codec.org/ last line win 64 binaries. I have win 7 64 bit
afaik there is no "codec" for opus. they provide an encoder and a decoder. the low level .dlls are also available but without an installer.
i'd try using MKVcleaver to extract the audio then run it through the decoder to wav. from there you can encode to whatever you want.--
Do you have lav installed ? Did you enable opus in the audio formats configuration tab ?
you mean https://github.com/Nevcairiel/LAVFilters/releases ? i installed the installer. still no sound with solveigmm. Says Unable to render audio. Necesary codecs not found..
Unable to sync AC-3 track with mkv (frame rate and audio delay issues)
By Revec in forum Newbie / General discussionsReplies: 18Last Post: 8th Jun 2018, 22:10 -
unable to install huffy codec on windows 7 .. [solved]
By vhelp in forum Newbie / General discussionsReplies: 26Last Post: 9th Jan 2017, 18:22 -
Direct Stream Video - But Keep Audio Codec & Change Bitrate in an MKV file
By TheRandomOne in forum Video ConversionReplies: 1Last Post: 4th Jan 2016, 22:00 -
SolveigMM Video Splitter 5 release with subtitles and multiple audio
By DmitryV in forum Latest Video NewsReplies: 0Last Post: 22nd Mar 2015, 04:06 -
Regarding Convert MKV or AVI to MP4 with Render in - Ubuntu Linux CLI
By baoky in forum Video ConversionReplies: 0Last Post: 17th Sep 2014, 06:59
