I want to reduce file size of my MKV rips and have been removing any redundant tracks. Are there any pros in keeping a DTS 5.1 audio file if a DTS-HD 5.1 is also available? Would there ever be an instance that DTS-HD 5.1 wouldn't be compatible or that I would need a DTS 5.1 over a DTS-HD 5.1 track?
DTS-HD contains both the DTS track along with residual corrective data to make it lossless, all in a single track. You can actually copy out the DTS track from the DTS-HD track. If your rip contains both a DTS and DTS-HD track, and they are the same mix and same language then I can't think of a reason to keep both tracks. From what I read, DTS-HD is supported on all DTS devices but if the device does not support DTS-HD then the residual corrective data is simply ignored and normal DTS is played.
One thing is very important - your player and your DTS decoder may be not able to deal with DTS-HD. For example older S/PDIF is unable to deal with anything higher than 1536kbps... So separate DTS may be more compatible even if every DTS decoder should ignore all extensions to DTS.
How to convert DTS-HD / HDMA With bitrate 1509kbps to DTS 755kbps ?
By PrinceSwaraj in forum AudioReplies: 16Last Post: 17th Apr 2018, 16:21 -
Quick help figuring out DTS track sizing
By CasanovaFly in forum AudioReplies: 16Last Post: 22nd Mar 2015, 19:54 -
MKV to Blu-ray keeping original DTS track is it possible?
By Pipemaster in forum Newbie / General discussionsReplies: 2Last Post: 14th Dec 2014, 12:38 -
How to get the track of sound effects and the music from Ac3 & DTS audio ?
By Abdo in forum AudioReplies: 2Last Post: 19th Oct 2014, 08:10 -
Dialog volume with DTS-MA track
By Phat J in forum AudioReplies: 2Last Post: 10th Sep 2014, 18:29
