I had a mini dv tape that I captured to an avi file with windv. For some reason the tape had 2 different audio sampling rates, 32 khz and 48 khz. The 32 khz plays fine but there is no audio on the 48 khz. During capture, I could hear the sound from the camcorder throughout the whole tape but avi file does not play the later part. It shows the video though.
I had one similar tape yesterday and it was easily fixed following the steps in the following thread:
https://forum.videohelp.com/threads/279415-Simplest-way-to-join-AVI-files-with-difffer...Sampling-rates
But the steps don't work on this tape.
Any suggestions will be highly appreciated.
Thanks.
Subhash -
Hmm. But how come the steps for video conversion in virtual dub in the thread posted above worked for my other avi.
Thanks.
Subhash -
DV avi files are different than standard avi files. Standard avi files are all equivalent to type2, but with no portion of the audio stream subsumed within the video stream.
Type1 dv has no separate audio stream - only the subsumed stream. Type2 dv has a copy of the subsumed stream pulled out to a standard audio stream, along with the original audio stream subsumed with video.
99percent of apps these days work with type2.
If windv capped a 32khz stream that should be 48 (or vice-versa), all the copy stream has audio and it is fairly trivial to do SRC on it.
If windv capped a mixed rate stream, the original subsumed stream will be mixed, but probably flagged as 1st-seen rate. The copy stream will probably be all 1st-seen rate (where the 2nd-seen rate will be off-speed & off-pitch, or worse, garbled & skippy), might be part heard & part silent, maybe just all silent. Depends on the smarts of the app.
But under no circumstances would it be expected to just track the rate and change mid-stream.
Capture in segments.
Scott -
Thanks Cornucopia for a detailed reply, half of which I didn't understand. LOL.
Bottom line is "Capture in segments".Thanks.
Subhash
How can i capture analog footage as a single file
By Sir_Loin in forum Capturing and VCRReplies: 10Last Post: 4th Mar 2016, 05:23 -
A single .m4v file to a single DVD-Video disk?
By Hamstor in forum Authoring (DVD)Replies: 7Last Post: 25th Sep 2015, 15:37 -
Bit Depth,Sampling Rate used for Uncompressed Audio-Bit Rate for Compressed
By alexander121 in forum AudioReplies: 9Last Post: 4th Apr 2015, 11:30 -
different sampling rate
By erzane in forum Newbie / General discussionsReplies: 10Last Post: 19th Jan 2015, 14:59 -
I Can't Get These Two AVIs on the Same Sampling Rate
By Slasher_101 in forum AudioReplies: 3Last Post: 23rd Jul 2014, 21:48
