Is this doable? I have a DTS audio track as well which has tripped up AVIDemux, MKVtoMP4 doesn't handle MVC.
Code:General Format : Matroska Format version : Version 2 File size : 33.7 GiB Duration : 1 h 45 min Overall bit rate mode : Variable Overall bit rate : 45.8 Mb/s Movie name : Dial M for Murder Encoded date : UTC 2019-02-08 21:56:31 Writing application : MakeMKV v1.14.2 win(x64-release) Writing library : libmakemkv v1.14.2 (1.3.5/1.4.7) win(x64-release) Original source medium : Blu-ray Video ID : 1 ID in the original source medium : 4113 (0x1011) Format : AVC Format/Info : Advanced Video Codec Format profile : Stereo High@L4.1 / High@L4.1 MultiView_Count : 2 Format settings, CABAC : Yes Format settings, ReFrames : 2 frames Format settings, GOP : M=1, N=10 Codec ID : V_MPEG4/ISO/AVC Duration : 1 h 45 min Bit rate mode : Variable Bit rate : 43.9 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.883 Stream size : 32.3 GiB (96%) Language : English Default : No Forced : No Audio #1 ID : 2 ID in the original source medium : 4352 (0x1100) Format : DTS Format/Info : Digital Theater Systems Format profile : MA / Core Mode : 16 Format settings, Endianness : Big Codec ID : A_DTS Duration : 1 h 45 min Bit rate mode : Variable / Constant Bit rate : 1 024 kb/s / 768 kb/s Channel(s) : 1 channel Channel positions : Front: C Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 spf) Bit depth : 24 bits Compression mode : Lossless / Lossy Stream size : 778 MiB (2%) Title : Mono Language : English Default : Yes Forced : No Audio #2 ID : 3 ID in the original source medium : 4352 (0x1100) Format : DTS Format/Info : Digital Theater Systems Mode : 16 Format settings, Endianness : Big Codec ID : A_DTS Duration : 1 h 45 min Bit rate mode : Constant Bit rate : 768 kb/s Channel(s) : 1 channel Channel positions : Front: C Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 spf) Bit depth : 24 bits Compression mode : Lossy Stream size : 579 MiB (2%) Title : Mono Language : English Default : No Forced : No Text ID : 4 ID in the original source medium : 4609 (0x1201) Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 1 h 44 min Bit rate : 92.2 kb/s Count of elements : 3454 Stream size : 68.6 MiB (0%) Language : English Default : No Forced : No 3d-plane : 2 Menu 00:00:00.000 : en:Chapter 01 00:01:09.069 : en:Chapter 02 00:06:54.288 : en:Chapter 03 00:08:49.487 : en:Chapter 04 00:10:53.653 : en:Chapter 05 00:13:53.666 : en:Chapter 06 00:18:51.421 : en:Chapter 07 00:24:25.130 : en:Chapter 08 00:29:52.916 : en:Chapter 09 00:33:10.989 : en:Chapter 10 00:39:06.344 : en:Chapter 11 00:42:15.908 : en:Chapter 12 00:46:44.510 : en:Chapter 13 00:50:32.612 : en:Chapter 14 00:53:34.211 : en:Chapter 15 00:54:21.174 : en:Chapter 16 00:59:40.660 : en:Chapter 17 01:03:09.911 : en:Chapter 18 01:07:11.694 : en:Chapter 19 01:12:02.318 : en:Chapter 20 01:13:04.880 : en:Chapter 21 01:18:43.260 : en:Chapter 22 01:21:47.402 : en:Chapter 23 01:27:37.794 : en:Chapter 24 01:33:26.183 : en:Chapter 25 01:36:06.677 : en:Chapter 26 01:41:03.348 : en:Chapter 27 01:43:52.309 : en:Chapter 28
Results 1 to 1 of 1
3D MVC muxing software
By tommy2010 in forum Video ConversionReplies: 1Last Post: 12th Mar 2018, 03:56 -
3D MVC-MKV zurück in 3D ISO
By EuYM in forum Blu-ray RippingReplies: 1Last Post: 14th Jul 2015, 14:31 -
3D DCP to 3D MVC ISO
By arthurm in forum Video ConversionReplies: 5Last Post: 8th Apr 2015, 03:16 -
How to play 3D mkv files? MVC video stream direct from 3D-Blu-rays
By flashandpan007 in forum Software PlayingReplies: 3Last Post: 7th Dec 2014, 03:01 -
Help converting MVC to SBS
By WOODY3d in forum Video ConversionReplies: 1Last Post: 23rd Nov 2014, 00:30
