Hi all,
I have the following video sample (length 15 secs), where the image got distorted after stabilization had been applied.
https://mega.nz/#!BUMQ1AQJ!7P5aEaMLxLaXsHtL62ep83NT6NNdVIriL1tcCMmSgWg
Which filter would you recommend to fix the distortion?
Many thanks!
				Results 1 to 10 of 10
	It looks like rolling shutter artifacts
 What did it look like before stabilization ?
 It was probably already there to some extent before; maybe the stabilizer you used exacerbated them
 What did you use to stabilize ? Some can take into account RS to some degree, such as mercalli, warp stabilizer . AE also has a rolling shutter repair filter
	Rolling shutter distortions are created by the camera. You probably just didn't notice them in the original video because of all the shaking. Once you remove the shaking the problem becomes very obvious.
	try mercalli on the original it has a mode for rolling shutter
 https://www.prodad.com/Video-Stabilization-for-Professionals/Mercalli-V4-SAL-Win-29795,l-us.html
	I applied "Light Stabilization" preset in Vegas. The shot was taken from inside the car while moving. Without stabilization it is even worst.
 I will try it and give you feedback on this.
 Somewhere I read that QTGMC filter in Avisynth can do some corrections, in terms of stabilization/rolling shutter artifacts (?) I am not sure because I didn't find the link anymore. If yes, can someone post the code, i would give a try with Avisynth first.
 Thank you
	avisynth RollAway filter http://forum.doom9.org/showthread.php?t=145549
 Yes, but vegas' light stabilization will not address the cmos rolling shutter issues;
 If you process it twice - you incur additional loss resulting in softer picture - because you're going to be zooming in and resizing/transforms twice
 I suggest using a proper stabilizer that can handle RS , like mercalli or warp stabilizer - and only once. Deshaker is not as good for RS handling, but go ahead and try it
 eg. warp stabilizer on your already processed video (you should get better results if you process original video) . The main goal here was to "fix" the warping / wobble from cmos artifacts , straighten up the buildings, etc...
 There are vibration artifacts and the motion blur in the source will cause the picture to go in/out of focus at times , even though the camera motion seems "smooth". It's a surreal experience, unnatural. But this is common for stabilized cmos video. There are ways to improve those frames by interpolating over them, but it requires user input to identify frame ranges
	@Nilzzon Thanks for the input. I will give it a try also with this one.
 @poisondeathray It looks good. What did you use to achieve this ?
 Unfortunately I don't have anymore the original video, as I am getting rid of the small pieces captured by the camera and I keep one long edited segment (yes, i know, bad habit)
 So I can only work with the already processed one.
  Stabilization / De-shaker choicesBy rhegedus in forum EditingReplies: 2Last Post: 28th Aug 2018, 07:57
  Question about stabilization with AvisynthBy tsk1979 in forum Newbie / General discussionsReplies: 1Last Post: 23rd Aug 2017, 10:56
  Severe StabilizationBy hohohohi888 in forum EditingReplies: 3Last Post: 4th Sep 2016, 13:21
  iMovie and StabilizationBy zoranb in forum Capturing and VCRReplies: 1Last Post: 28th Sep 2014, 08:25
  Help with StabilizationBy henryperu77 in forum RestorationReplies: 6Last Post: 1st Apr 2014, 21:35
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
