At the moment I'm using QTGMC to deinterlace and denoise my videos, and it works pretty well except that that at the moment I need to throw out half my frames.
The deinterlacer splits one interlaced frame into two progressive frames, doubling the framerate, but it seems to be placing the two new frames in the wrong order, resulting in a jitter that is only solved by throwing away half of the frames.
Is there a way to ensure that QTGMC places the frames in the correct order?
At the moment, this is my current script in its entirety:
EdiMode="EEDI3", EdiMaxD=16, TrueMotion=true were added in an attempt to get QTGMC to better detect which way the frames should be arranged. They didn't seem to do anything, or at least nothing that I was looking for, namely the frames falling in the correct order.Code:sourceOne=AVISource("Wedding unedited pt1.avi") sourceTwo=AVISource("Wedding unedited pt2.avi") trimmedPartOne = sourceOne.Trim(10, 221060) trimmedPartTwo = sourceTwo.Trim(28,36025) mergedSource = trimmedPartOne + trimmedPartTwo #chroma restoration for analog source material chroma=mergedSource.Cnr2("oxx",8,16,191,100,255,32,255,false) cleaned = chroma.QTGMC(Preset="slow", EZDenoise=2.0, EdiMode="EEDI3", EdiMaxD=16, TrueMotion=true)#.SelectEven() #Commented out attempts to degreen the video as seen in another thread I've posted. return cleaned
The two clips are video that has been recorded across two VHS tapes by the same camera at roughly the same time, which I'm joining together into a single video after cutting off the static on each end. I can process the two clips separately, though I haven't noticed any issues with processing them joined together yet.
You need to assume the correct field order for each video before using QTGMC or any deinterlacer . By default, avisynth assumes BFF (bottom field first) . If you get jerky fwd/back, it's TFF (top field first)
sourceOne=AVISource("Wedding unedited pt1.avi").AssumeTFF()
sourceTwo=AVISource("Wedding unedited pt2.avi").AssumeTFF() -
That did it, thanks! I'm sorry if this was a basic question. I'm learning as I go and didn't find any explanation of why it was doing that searching.
Help with QTGMC?
By attackworld in forum EditingReplies: 3Last Post: 26th Nov 2018, 22:57 -
Frustrated with QTGMC
By guayabito in forum Newbie / General discussionsReplies: 19Last Post: 8th Oct 2018, 05:15 -
qtgmc not loading
By yukukuhi in forum EditingReplies: 3Last Post: 16th Sep 2016, 08:41 -
QTGMC error
By bakonfreek in forum Newbie / General discussionsReplies: 13Last Post: 13th Dec 2014, 23:08 -
I Need Perfect Help QTGMC Deinterlacing Script On MeGui
By arcte in forum Video ConversionReplies: 21Last Post: 11th Oct 2014, 08:01
