I assume it came packaged with Haali Media Splitter. It's broken all my plugins.
How do I get rid of it and go back to my old install? That folder is still in my Program Files folder, with all my plugins intact, it's just evidently being overridden by +.
Since there isn't much development on non-+ AviSynth have you considered simply copying all your plugins into the new plugin folder? It's good software.
To actually answer your question:
In the registry under [HKEY_LOCAL_MACHINE\SOFTWARE\Avisynth] you can find and change the plugin dir(s). Try setting it back to the old one. Overwrite AviSynth.dll (usually in C:\Windows\SysWOW64\ or C:\Windows\System32\) with the old one if necessary (running the installer should do that as well).
P.S.: AviSynth+ is not part of Haali. Did you run RipBot? I had a similar problem once. It does some unwanted system changes ...
Installed Codecs and LAV Filters
By Nitobert in forum Video ConversionReplies: 4Last Post: 30th Jan 2017, 05:29 -
How do you know if your encoder installed?
By Guernsey in forum Newbie / General discussionsReplies: 2Last Post: 25th Aug 2016, 14:50 -
DirectShow not installed
By jarko in forum Newbie / General discussionsReplies: 15Last Post: 20th Jul 2014, 19:24 -
Microsoft accidentally borks legit websites
By enim in forum Off topicReplies: 1Last Post: 2nd Jul 2014, 10:27 -
avisynth - How to write avisynth script for rgba overlay
By moelover in forum EditingReplies: 3Last Post: 13th Apr 2014, 13:24
