After EVERY reboot I do, I have to re-install EzGrapper for it to work !!
I have set it to use the desktop as storage place ... and shall say it does ...
After EVERY reboot - now I have tried 6-8 times - it pollutes my whole desktop with empty files - just running loose like a goose
You can't stop it unless you KILL the program !
Where can I get an updated version ?
Where did you get, or download, it?
What does that mean?
How do you know it's the program you mention that's 'polluting' your desktop? What does 'polluting my desktop' mean? Can you explain further?
Doesn't the program have an 'About' box? Update link? What's the company name? Have you been there? -
Not even Google knows about "EzGrapper", except for the fact that it is mentioned in this thread. Google does know of EZgrabber software, which seems to have been included with Diamond Multimedia's VC500, as well as some crappy USB capture devices from no-name companies that offer no customer support.
Development on EZgrabber probably ended some time ago. Perhaps you need to consider using different softwareIgnore list: hello_hello, tried, TechLord, Snoopy329 -
try to go into proprieties/comptability and set it for windows 7
and for what i've read ezgrabber is only usefull for it's driver
capture with another software virtualdub (advanced) or amarectv (may be easier)
use a loseless codec for capture (huffyuv , big files)
and recompress it with a good encoder for use (avstodvd or vidcoder)
run Ccleaner to get garbage out of your system -
I don't know if Virtualdub works well with Windows 10. VirtualDub2 could be a better choice with Windows 10.
VOB2MPG doesn't work on Windows 10
By armyofquad in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 27th Dec 2024, 18:25 -
why the script doesn't work correctly ?
By zanzar in forum Newbie / General discussionsReplies: 1Last Post: 21st May 2017, 17:33 -
TS to AVi/MP4/WMV/HD doesn't work... :(
By langf in forum Video ConversionReplies: 9Last Post: 19th Apr 2015, 13:44 -
Handbrake Doesn't Seem To Work
By Arthur_Ballsack in forum Newbie / General discussionsReplies: 5Last Post: 12th Jul 2014, 15:39 -
Deshaker doesn't work
By timsky in forum RestorationReplies: 8Last Post: 9th Jul 2014, 06:09
