[Edited]
Probably ffmpeg defaults to bt601 colors while HD video is usually assumed bt709.
Try adding:
Code:-vf zscale=m=bt709:d=ordered
This is a separate issue. Different browsers, OS, GPU drivers etc. can produce different displays. You cannot influence this. My recommendation is to always upload HD video as bt709 and hope Google et. al. someday figure out how to correctly display everything on all systems.Last edited by sneaker; 7th Feb 2019 at 07:47.
Yes, it's a rec.601 vs rec.709 issue. HD video should use the rec.709 matrix to convert between RGB and YUV. Whenever possible flag the video as rec.709 (some codec and containers don't allow for this). Even with properly converted and flagged rec.709 you may not get the proper colors in some players/editors. Some always use rec.601. Some always use rec.709. Some assume rec.601 for low res, rec.709 for high res. Some will look for flags and act accordingly.
Extract DTS-MA from MKV in highest quality (FLAC or PCM)
By x8009 in forum AudioReplies: 2Last Post: 1st Jan 2019, 17:33 -
FFMPEG how to merge 2 stereo .wav audio files into one of 4 channels?
By marcorocchini in forum Newbie / General discussionsReplies: 4Last Post: 24th Jun 2018, 07:25 -
color correction for white balance wrong?
By marcorocchini in forum Newbie / General discussionsReplies: 7Last Post: 24th Jul 2017, 21:22 -
Avisynth FFmpegSource2 wrong color space
By Veggav in forum EditingReplies: 3Last Post: 10th Apr 2016, 09:47 -
Cut MKV with FLAC audio
By rjc7394 in forum Video ConversionReplies: 1Last Post: 30th Nov 2014, 10:24
