Hey, i am trying to convert an animation BluRay i have from 29.97 1080i to 23.976 1080p without interlacing or ghosting artifacts and i am struggling to figure out how, i have tried handbrake & staxrip using IVTC and deinterlacing but there always seems to be some ghosting present. Is this a case of i have to do more than just IVTC/Deinterlace? or am i just screwing it up completely I have provided a 50 sec clip of the source material i am trying to convert for reference, can anyone here set me on the right path?
https://www62.zippyshare.com/v/r4owhilz/file.html
This is the only season that was released in 1080i and it's bugging me to not have it the same as the rest!
The file has more than 1 blended frame per 5, so simply removing 1 out of 5 frames won't perfectly restore 23.976fps. If the file had been telecined then this would be an easy fix but it's not. Srestore for avisynth would still be your best option for removing most of the blended frames.
That video was blend deinterlaced before being encoded. SRestore() won't work. FixBlendIVTC() + TDecimate() is probably your best hope. Or mabye FixBlendIVTC() + SRestore(frate=23.9076).
I tried FixBlendIVTC() & TDecimate() and it removed some of the ghosting but not all of it, FixBlendIVTC() & SRestore(frate=23.976) just crashes Staxrip so i can't test that.
Here's the same sample with FixBlendIVTC() used:
https://www115.zippyshare.com/v/7hIRtCVu/file.html -
You'll probably have to play around with the FixBlendIVTC settings. I haven't really used the program much so I can't really help with it. Using SRestore() instead of TDecimate() should reduce the number of blended frames. You might need to find an older version of SRestore if you're using 64 bit. I believe you need v2.7f or earlier.
Ok, thanks for trying to help. I have tried playing around with the settings of FixBlendIVTC but it doesn't seem to change what it's doing to the video in any way. I got FixBlendIVTC & Srestore to work together thanks to your tip about using v2.7f, and it has improved the video more but there is still a few blended frames remaining. Getting there slowly but would gladly take anymore tips anyone has
Handbrake 1080i to 1080p or 720p settings?
By pipelineaudio in forum Newbie / General discussionsReplies: 10Last Post: 29th Mar 2017, 21:35 -
Help me with 1080i to 1080p
By cybero75 in forum Video ConversionReplies: 8Last Post: 6th Mar 2016, 08:35 -
Best option to convert 1080i 50fps to 1080p 25/30
By Fadedown in forum Video ConversionReplies: 2Last Post: 26th Aug 2015, 10:35 -
1080i and 1080p is confusing?!
By Robert Bradford in forum Newbie / General discussionsReplies: 18Last Post: 25th Apr 2015, 14:03 -
How to convert 1080p to 1080i using FFMPEG
By nitinsagar22 in forum Video ConversionReplies: 10Last Post: 19th Mar 2014, 16:47
