Hello all. I am new to using FFMPEG to download streams. I am very impressed with it and enjoying learning about it a lot. But I am just getting going, so I have some questions for more experienced users.
1. Is there any way to automate downloads of multiple videos/video stream chunks? Queue a bunch up somehow? Use a list of files to download and automate downloading? Would a GUI for FFMPEG perhaps assist in this?
2. What is the best way to batch process combining multiple videos that download in multiple pieces? I already know how to combine them, I just want a way to do batch. Again, would a certain FFMPEG GUI help here? All I would be doing is combing the pieces of the same video, no conversion, encoding, whatever...
3. Is there any way to download the videos/video chunks with the original name of the video and following it a 1, 2, 3, etc... for each chunk as opposed to output.mp4 like I currently am doing and then having to rename each one manually before I can download again? How do you get the file name and apply it to the download? Even a 1, 2, 3, etc... (with no file name) naming scheme would be better... And to clarify a command line code would have to save them as one number higher each time. Any unique name really would do, with something relating to the filename, and position of each chunk being optimal of course. And is it possible to send all of the chunks for one video to a folder of that same name for organizations sake?
I think that's about it for now. Hopefully someone can give me some good advice to streamline my operation.Thanks in advance!
Results 1 to 10 of 10
In Windows command/batch file, read filenames (or URLs) one line at a time from a text file, process with FFmpeg, and output with an incrementing number.
Code:setlocal enabledelayedexpansion set index=0 for /f "delims=" %%F in (myfilelist.txt) do ( set /a index+=1 ffmpeg.exe -i %%F [options] output_!index!.mp4 [or whatever the extension is] ) -
Wow, that sounds great! Thanks for the suggestion, and the code to do it, can't wait to give it a try.
"Or, since you're building a list of files, you can just call ffmpeg sequentially in a simple batch file:
ffmpeg -i URL1 FileName1.mp4
ffmpeg -i URL2 FileName2.mp4
ffmpeg -i URL3 FileName3.mp4
I'm not sure how to make a batch file, I'll look into it. However, I like the idea of this doing it this way. I'm currently putting the download code in before & after the stream URLs I'm downloading in Notepad++, then copying into a command prompt with admin rights to download, so I think it shouldn't be too hard to convert them to a batch file and then I can do them all with one command hopefully. So great idea, thanks!
"setlocal enabledelayedexpansion
set index=0
set /a index+=1
I can't for the life of me get this line of code to work. I tried doing it all kinds of different ways, and it just always gives errors. I went the route of putting the file that is the download list and the ffmpeg.exe file in the same folder and trying to run the script on them that way, but no go. I tried editing it all kinds of different ways. The only code I myself use for my process of downloading and combining is:
ffmpeg -i "URL HERE" -c copy -bsf:a aac_adtstoasc "output.mp4"
(for downloading)
and:
(for %i in (*.mp4) do @echo file '%i') > mylist.txt
ffmpeg -f concat -i mylist.txt -c copy output.mp4
(for combining)
It was frustrating I'm not getting it to work, but it is at least telling me how the code needs to be structured to work if I put things in the wrong order, so that's nice and helpful anyways. I will have to give it another go later... -
A batch file is just a text file with all the commands you want to run -- but with the extension .BAT instead of .TXT. You can create it with any text editor, like NotePad. The code that JVRaines gave is also a batch file. To run a batch file you can double click on it in Explorer. Or open CMD.COM and type the name of the batch file.
ffmpeg will automatically concatenate segments if you give it a playlist (m3u8, mpd, etc.) rather than the individual filenames. -
Success, the batch file works great!
Thanks Jagabo! Is there any way to leave the command prompt open at the end of the process to check the command prompt window for downloading errors? Thanks again for the batch file suggestion, now I can download while I sleep or work.
The stuff I put in square brackets is comment/pseudocode only and should not be used literally.
- If the folder containing the FFmpeg executable file is not in your environmental PATH variable and the current folder is not the folder containing ffmpeg.exe, then you have to specify the complete path to the file. For example, "c:\program files\ffmpeg\bin\ffmpeg.exe". If the path contains spaces, it must be enclosed in double quotes.
- If the current folder is not the folder containing the text file with the list of file names, then you have to specify the complete path to the file. If the path contains spaces, it must be enclosed in double quotes.
- [options] must be replaced with the options you are passing to FFmpeg.
Code:setlocal enabledelayedexpansion set index=0 for /f "delims=" %%F in (myfilelist.txt) do ( set /a index+=1 ffmpeg.exe -i %%F -c copy -bsf:a aac_adtstoasc output_!index!.mp4 ) -
@JVRaines
Script revision works perfectly man, thanks!
@jagabo
Pause works perfectly, thanks bro!
General questions using ffmpeg on xp and windows 7 to download
By jimdagys in forum Video Streaming DownloadingReplies: 3Last Post: 16th Nov 2017, 13:49 -
Some basic questions about using ffmpeg to download pbs videos
By jimdagys in forum Video Streaming DownloadingReplies: 38Last Post: 26th Mar 2017, 14:37 -
(Willing to pay)ffmpeg Need help downloading live stream ffmpeg and rtmp
By grabyea in forum Video Streaming DownloadingReplies: 0Last Post: 10th Apr 2016, 16:54 -
Random questions...Camtasia, ffmpeg, video joining...Editing..
By DiSaSseMbLeDmNd in forum Newbie / General discussionsReplies: 8Last Post: 3rd Apr 2016, 16:36 -
Questions about FFmpeg and HandBrakeCLI
By Pane in the Glass in forum Video ConversionReplies: 2Last Post: 13th Sep 2015, 18:12
