https://forum.videohelp.com/threads/343458-DVD-Recorder-to-use-as-a-pass-thru-TBC-Need-HELP
I just came across this forum post just now since I am doing something similar transferring vhs to digital at best quality. I was just reading in here Panasonic DMR-EZ48VK is bad. I know it has freezing issues but is it bad for VHS playback? It is the first time I am hearing Toshiba and Magnavox being recommended over Panasonic and JVC. Which Toshiba and Magnavox DVD/VCR recorder models are recommended over Panasonic EZ48VK. I have a Sanyo DVD/VCR (AV only) combo also but comparing both playbacks clearly the EZ48VK was better (on all outputs HDMI, RGB, and AV ). What about Samsung DVD/VCR recorder combo? I think the VCR still works on it. Is it better than EZ48VK? Another question is does the EZ 48VK have a builtin TBC?
Results 1 to 1 of 1
Is a full frame TBC necessary or VCR's builtin TBC enough?
By DNICE_ONE in forum Capturing and VCRReplies: 37Last Post: 22nd Dec 2018, 15:03 -
I mean audieo recorder (home cassette deck), does it have TBC function.
By 280634157 in forum Capturing and VCRReplies: 2Last Post: 23rd May 2018, 02:47 -
Who uses a DVD recorder as a line TBC, and what do you use?
By BrainStorm69 in forum Capturing and VCRReplies: 190Last Post: 5th Jun 2017, 09:26 -
Correct way to connect a Panasonic ES10/15 as a pass through line TBC
By jimj in forum Capturing and VCRReplies: 14Last Post: 23rd May 2016, 16:39 -
TBC in Panasonic DVD recorder?..
By pippas in forum Capturing and VCRReplies: 9Last Post: 5th Dec 2014, 10:32
