Which free antivirus/firewall would you suggest?
	I use https://sphinx-soft.com/Vista/order.html "Windows 10 Firewall Control". Have no real-time anti-virus thus can't advise on this however if you are implementing good habits then using anti-virus scanner is OK.
	Hi Kyrcy,
 Firewall app (5/5): Windows Firewall Control
 Antivirus (4.5/5): Kaspersky Free
 Claudio
	I use Comodo firewall and Avast antivirus with W10. Both freeware.
 Windows own firewall is useless, as is Defender, IMO.
	No as bad since Vista https://en.wikipedia.org/wiki/Comparison_of_firewalls#Firewall_rule-set_Appliance-UTM_...res_comparison and Comodo is resource hungry solution... if you have multicore CPU and plenty of RAM then perhaps not so important but in case of 2 core CPU with limited RAM it is unacceptable solution.
	surprisingly microsoft's own widow's defender is now been upgraded and is good enough on it's own to use. https://www.tomsguide.com/us/best-free-antivirus,review-6003.html --
	I use Comodo Internet Security, but I find it a little too heavy for my taste and I usually disable several of its components. I do however appreciate the fact that it's the only truly free antivirus/firewall I found that does not nag to upgrade to a paid software. Unless I missed something?
  how to kill Windows Defender ANTIVIRUS?By marcorocchini in forum Newbie / General discussionsReplies: 3Last Post: 1st Jan 2018, 07:11
  Free firewall installationBy shans in forum ComputerReplies: 10Last Post: 9th Jul 2016, 11:13
  Need advice for free antivirus+free firewall comboBy alegator in forum ComputerReplies: 16Last Post: 6th Jul 2016, 18:21
  AntiVirus message keeps flashingBy shans in forum ComputerReplies: 8Last Post: 11th Aug 2015, 23:57
  Best antivirus program for detecting keyloggers?By sdsumike619 in forum ComputerReplies: 16Last Post: 17th Apr 2014, 09:59
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
