i am trying to find the plugins i used in Avisynth , to be ported to.
1.does Avisynth dll's will be usable in vapoursynth? , if not how can i use them or can i convert them myself?
need stuff like : ColorMatrix,levels,tweak(".."),Hysteria,Sharpen, Blur ,nnedi3(actually got that one working),McTemporalDenoise,GradFun3,Dehalo_alpha.
VapourSynth has equivalents for all of those. Check the documentation and vsdb.
colormatrix
Vapoursynth uses powerful Resize filter, that resizes video resolution, changes colorspaces or bit depth as well. To just change colorspace from NTSCDV format to BT709:
matrix_in_s argument is string input colorspaceCode:import vapoursynth as vs from vapoursynth import core clip = core.resize.Bicubic(clip, matrix_in_s = '170m', matrix_s = '709')
matrix_s means string output value
matrix_in expects numeric (int) value
matrix expects also numeric value
so that '_s' stands for string instead of number
correlation between numbers and strings as for matrix is:
{0:'rgb', 1:'709', 2:'unspec', 3:'reserved', 4:'fcc',
5:'470bg', 6:'170m', 7:'240m', 8:'ycgco', 9:'2020ncl',
10:'2020cl' , 100:'OPP',
so for example if your SD resolution is PAL and you for example resize using nnedi3 somewhere in the script , resizing to HD, and then you change colorspace in this line:
orCode:clip = core.resize.Bicubic(clip, matrix_in_s = '470bg', matrix_s = '709')
that's the same commandCode:clip = core.resize.Bicubic(clip, matrix_in = 5, matrix = 1)
Also be prepared for more restrictive approach, for example if loading NTSCDV with ffms2 source plugin into 4:1:1 (avisource loads NTSCDV as 4:2:0) you have to crop width with mod 4 and height with mode 2, otherwise you'd get error. It would not crop in the middle of subsampling. NTSC 4:1:1 has one color for four x pixels.
Help transitioning from avisynth to vapoursynth.
By zanzar in forum Newbie / General discussionsReplies: 10Last Post: 3rd Feb 2019, 17:50 -
Debading method (Vapoursynth to avisynth)
By frank_zappa in forum RestorationReplies: 2Last Post: 3rd Nov 2017, 13:26 -
Problems loading plugins into AVISynth
By bvdd in forum Video ConversionReplies: 51Last Post: 20th Nov 2015, 08:15 -
x264 and ffmpeg equivalent commandline with avisynth
By mindphasar in forum Video ConversionReplies: 2Last Post: 7th Apr 2015, 18:26 -
HELP! MeGUI can't load certain avisynth plugins
By Throw_Hammer in forum Newbie / General discussionsReplies: 3Last Post: 22nd Feb 2014, 18:19
