    Dec 2007
    Hello
    I used to have directions on how to do this but i lost contact with the person who gave me it. I have mkv that is 1920x1044 and is 23.2 gb and it has DTS-HD 7.1 sound. When I had the directions I was able to convert the resolution to 1920x1080 and the resulting bd files were able to fit on a 25gb disc. my question is what are the recommended settings to do this in bd rebuilder? Also, can this program or any other program can do the same as described above but with a Dolby TrueHD 7.1? Alot of people are asking about that is there a solution yet? i know tsmuxer doesn't support dolby atmos.
    Last edited by GTAGamesLvr; 13th Feb 2019 at 03:36. Reason: my original title was not clear enough
    Dec 2007
    deleted
    Dec 2007
    if this topic was discussed on here before can someone at least provide a link? ive searched.
    Dec 2007
    thanks october. do you happen know how i can use bdrebuilder to make a mkv that's 1920x1044 to 1920x1080? i did that in the past but like i said i lost the instructions.
