I have a number of 'split' DVD's (in the original vob format) that I want to convert to a single mp4. I already converted most of these to mp4's, I just need to join them.
I have spent part of a day trying to find a somewhat simple 'Joiner'/'Merge' program, but couldn't.
I thought MP4Tools was it, but after wasting an hour I now find out it's only a 'Wintel' program, no AMD which is BS. It would of been the ideal program except for the authors narrow-mindedness.
Most of the basic 'video editors' don't seem to have a 'join' option that I could see. I did try Movavi, but the resulting file was humongous. The two test files I was 'joining' were only around 850MB, but the end result, even after using a 'custom' resolution (716x366), the resulting size was 1.4GB, almost twice the size. No idea why.
Any suggestions? I really don't need a full editor.
				Results 1 to 11 of 11
	Last edited by videobruce; 4th Apr 2019 at 10:07. Reason: clarified text Why are ones and zeros so complicated? Linear Video Editing was easier. Downloading & streaming are two different things.
	TMPGEnc Smart Renderer (payware, with trial)
 Totally worth it.
 Can also fix constant audio skew.Want my help? Ask here! (not via PM!)
	VOBs on DVD are split after 1 GB on a binary level. It is recommended you first append the VOBs (e.g. using ffmpeg's "concat protocol" *), then convert to whatever you want. Otherwise you risk problems at the split points.
 * (You can read about ffmpeg's appending modes ("concat demuxer" as mentioned by sfu10 vs. "concat protocol") here.)
	You can "concatenate" them too. In a DOS window. I just don't remember how to do it. I did do it myself before, so I know its doable. Heck yeah, theres no reencoding either.
 Thats one of the reasons why Mpeg2 is an excellent editing format.Last edited by budwzr; 6th Feb 2019 at 16:55.
	Sorry, apparently I never received notice of any of these replies.
 I should of made it clearer that when I stated "vob's" I was referring the the DVD format, not the individual vob files within a movie.
 I have started using FormatFactory which seems to be working ok, but I will look into Avidemux.Last edited by videobruce; 4th Apr 2019 at 10:36. Why are ones and zeros so complicated? Linear Video Editing was easier. Downloading & streaming are two different things.
	STRONGLY recommend you use something like DVDDecrypter (YES, that old program) for this first part.
 Reason: most concatenators don't properly match up the PTS/DTS of the streams, so you end up with glitches, especially in the audio. DVDDecrypter, and some other similar apps can read the IFO/BUPs and map the PTS/DTS across the file boundaries throughout the whole length of the title, so you can end up with a single HUGE VOB or MPG, which will convert to your final destination format much more easily and cleanly.
	"concatenators" Huh??? Why are ones and zeros so complicated? Linear Video Editing was easier. Downloading & streaming are two different things.
  batch joiner programBy RBCC in forum EditingReplies: 0Last Post: 31st May 2018, 17:55
  How to merge two videos of the same tape?By videon00b in forum EditingReplies: 4Last Post: 15th Jan 2018, 01:20
  i am looking for a free mp4 cutter joinerBy sommers in forum Newbie / General discussionsReplies: 1Last Post: 25th Aug 2016, 05:55
  How to merge videos that start at different times?By Chibears85 in forum EditingReplies: 3Last Post: 2nd Aug 2015, 20:35
  Merge Video from one MP4 with Audio from another MP4 - How?By GrayStrickland in forum EditingReplies: 6Last Post: 10th Feb 2014, 05:45
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
