I recently replaced an Android TV box with a NVIDIA Shield TV. Kodi 17.6 has issues on the Shield 7.2.2 so I installed Kodi 18. That fixed the original issues but now none of my AVI's will play unless I change the Kodi settings to eliminate HW acceleration. That of course causes issues with other file types.
I have used a few different "AVI fixer" apps which found no issues with my AVI files and I have even changed the container to MKV. That did not help. The files are old and someone suggested that GMC2 / QPel may be the problem. I have come to the conclusion that the only option is to re-encode them. I believe the older versions of Kodi automatically turned off HW acceleration for files smaller than 800 pixels wide but Kodi 18 does not do this. I went out and bought a GeForce GTX 1060 card and used ffmpeg but the resulting files are almost twice as large as the originals and I see a degrade in quality. Below is the command line I used:
There must be a happy compromise. Can someone please suggest some other commands or software and settings for me to try? There must be a way to see little to no quality loss converting to h.265 without increasing the file size, isn't there?Code:for /R %%I in (*.avi) do ffmpeg -i "%%I" -c:v hevc_nvenc -preset slow -cq 18 -g 150 -c:a aac -b:a 160k "%%~nI.mkv" & echo del "%%I"
Below is a link to one of the hundreds of files I want to convert:
AVI file (135 MB):
https://filebin.net/b83fiziyyz9jc6l9
MediaInfo:
I have many files so I thought using hevc_nvenc would be the best option.Code:General Complete name : C:\1.avi Format : AVI Format/Info : Audio Video Interleave File size : 136 MiB Duration : 22 min 26 s Overall bit rate : 845 kb/s Writing application : VirtualDubMod 1.5.1.1a (build 1639/release) Writing library : VirtualDubMod build 1639/release Video ID : 0 Format : MPEG-4 Visual Format profile : Advanced Simple@L3 Format settings : GMC2 / QPel Format settings, BVOP : No Format settings, QPel : Yes Format settings, GMC : 2 warppoints Format settings, Matrix : Default (H.263) Codec ID : XVID Codec ID/Hint : XviD Duration : 22 min 26 s Bit rate : 643 kb/s Width : 640 pixels Height : 480 pixels Display aspect ratio : 4:3 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Compression mode : Lossy Bits/(Pixel*Frame) : 0.087 Stream size : 103 MiB (76%) Writing library : XviD 0.0.09 (UTC 2003-03-25) Audio ID : 1 Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Format settings : Joint stereo / MS Stereo Codec ID : 55 Codec ID/Hint : MP3 Duration : 22 min 26 s Bit rate mode : Constant Bit rate : 192 kb/s Channel(s) : 2 channels Sampling rate : 48.0 kHz Compression mode : Lossy Stream size : 30.8 MiB (23%) Alignment : Split accross interleaves Interleave, duration : 42 ms (1.00 video frame) Interleave, preload duration : 464 ms
Below something that worked for h.264 - try to match similar for hevc - have no NVidia hardware thus unable to help you more. Consult with latest NVidia NVenc recommendations, also remember to upgrade driver to newest possible version.
Code:@ffmpeg.exe -hide_banner -v 32 -stats -y -i "%filename%" -vf %vproc% -c:v h264_nvenc -level:v 4.0 -preset:v hq -profile:v high -cq %vq% -qmin:v 8 -qmax:v 29 -bufsize:v 10000k -maxrate:v 20000k -g 250 -bf 3 -refs:v 3 -rc:v vbr_hq -rc-lookahead 32 -b_adapt 1 -temporal-aq 1 -spatial-aq 1 -i_qfactor 0.75 -b_qfactor 1.1 -coder:v cabac -bluray-compat 1 -aud 1 -aq-strength 8 -af %aproc% -c:a ac3 -b:a %ab%k "%~n1_delogdaudnv.mkv"
try testing with only converting the audio to aac, and copy the video track into an mp4 container
FFMPEG Compand settings suggestions please...
By VideoGuruDude in forum AudioReplies: 12Last Post: 24th Dec 2022, 17:54 -
Which codec and settings to use with FFmpeg for temporary transcoding?
By konstantinusz in forum Video ConversionReplies: 15Last Post: 4th Dec 2016, 19:07 -
Help with ffmpeg settings H265
By remainz in forum Video ConversionReplies: 1Last Post: 8th Jun 2016, 13:54 -
FFMPEG gop settings.
By Prathamesh in forum Video ConversionReplies: 2Last Post: 20th Jul 2015, 11:17 -
FFmpeg best settings to encode Blu-Ray
By MvL in forum Video ConversionReplies: 3Last Post: 8th Jul 2014, 17:55
