any chance for bbc iplayer ?
tried with youtube -dl, with no luck.
youtube-dl --verbose https://www.bbc.co.uk/sounds/play/m00028jn
[debug] System config: []
[debug] User config: []
[debug] Custom config: []
[debug] Command-line args: ['--verbose', 'https://www.bbc.co.uk/sounds/play/m00028jn']
[debug] Encodings: locale cp1252, fs mbcs, out cp437, pref cp1252
[debug] youtube-dl version 2019.01.30.1
[debug] Python version 3.4.4 (CPython) - Windows-10-10.0.17134
[debug] exe versions: ffmpeg 3.4, ffprobe 3.4
[debug] Proxy map: {}
[bbc] m00028jn: Downloading webpage
ERROR: no suitable InfoExtractor for URL https://www.bbc.co.uk/programmes/None
File "__main__.py", line 19, in <module>
File "C:\Users\dst\AppData\Roaming\Build archive\youtube-dl\rg3\tmp36zpl0n4\build\youtube_dl\__init__.py", line 472, in main
File "C:\Users\dst\AppData\Roaming\Build archive\youtube-dl\rg3\tmp36zpl0n4\build\youtube_dl\__init__.py", line 462, in _real_main
File "C:\Users\dst\AppData\Roaming\Build archive\youtube-dl\rg3\tmp36zpl0n4\build\youtube_dl\YoutubeDL.py", line 2005, in download
File "C:\Users\dst\AppData\Roaming\Build archive\youtube-dl\rg3\tmp36zpl0n4\build\youtube_dl\YoutubeDL.py", line 804, in extract_info
File "C:\Users\dst\AppData\Roaming\Build archive\youtube-dl\rg3\tmp36zpl0n4\build\youtube_dl\YoutubeDL.py", line 865, in process_ie_result
File "C:\Users\dst\AppData\Roaming\Build archive\youtube-dl\rg3\tmp36zpl0n4\build\youtube_dl\YoutubeDL.py", line 827, in extract_info
File "C:\Users\dst\AppData\Roaming\Build archive\youtube-dl\rg3\tmp36zpl0n4\build\youtube_dl\YoutubeDL.py", line 621, in report_error
File "C:\Users\dst\AppData\Roaming\Build archive\youtube-dl\rg3\tmp36zpl0n4\build\youtube_dl\YoutubeDL.py", line 583, in trouble
I used Tubedigger trial (free) from this public computer and it downloaded the audio (96kbps) no problem. The free trial downloads 50% of the file, in this case that was 30 minutes of music.
Use Developer Tools (F12) in a browser and look for the mpd link:
Then use that link with youtube-dl:Code:https://aod-dash-ww-live.akamaized.net/usp/auth/vod/piff_abr_full_audio/77dc1e-m00028jm/vf_m00028jm_c40582ab-816d-4ae9-9c67-ef4d30786b4b.ism/pc_hd_abr_v2_nonuk_dash_master.mpd?__gda__=1549180285_5f07828e337dcc5ea2cc92a83c9b6a2a
Available streams:Code:youtube-dl "https://aod-dash-ww-live.akamaized.net/usp/auth/vod/piff_abr_full_audio/77dc1e-m00028jm/vf_m00028jm_c40582ab-816d-4ae9-9c67-ef4d30786b4b.ism/pc_hd_abr_v2_nonuk_dash_master.mpd?__gda__=1549180285_5f07828e337dcc5ea2cc92a83c9b6a2a"
mpd/m3u8 Links like this often expire every few minutes so you may have to get a fresh one.Code:youtube-dl -F https://aod-dash-ww-live.akamaized.net/usp/auth/vod/piff_abr_full_audio/77dc1e-m00028jm/vf_m00028jm_c40582ab-816d-4ae9-9c67-ef4d30786b4b.ism/pc_hd_abr_v2_nonuk_dash_master.mpd?__gda__=1549180285_5f07828e337dcc5ea2cc92a83c9b6a2a [generic] pc_hd_abr_v2_nonuk_dash_master: Requesting header WARNING: Falling back on generic information extractor. [generic] pc_hd_abr_v2_nonuk_dash_master: Downloading webpage [generic] pc_hd_abr_v2_nonuk_dash_master: Extracting information [info] Available formats for pc_hd_abr_v2_nonuk_dash_master: format code extension resolution note audio_eng_1=48000 m4a audio only [en] DASH audio 48k , m4a_dash container, mp4a.40.5 (48000Hz) audio_eng_1=96000 m4a audio only [en] DASH audio 96k , m4a_dash container, mp4a.40.5 (48000Hz) (best)
I once managed to capture a (radio) Sounds program from the BBC website, with the MacX Youtube Downloader, (Festival of Nine Lessons 2018) but now i can't repeat that same "action" anymore, my guess is the BBC is very "sharp" on monitoring their website
it's easy to convert the AAC file though..
BBC i player
By David Banner in forum Video Streaming DownloadingReplies: 21Last Post: 27th Dec 2018, 12:14 -
Downloading from BBC store
By Harry101 in forum Video Streaming DownloadingReplies: 4Last Post: 20th Jun 2017, 08:05 -
BBC Iplayer
By Dunmanway in forum ComputerReplies: 1Last Post: 8th Jun 2017, 03:21 -
BBC iplayer help --
By dongy789 in forum Video Streaming DownloadingReplies: 1Last Post: 10th May 2017, 17:01 -
BBC Worldwide on youtube
By Spiny Norman in forum Video Streaming DownloadingReplies: 11Last Post: 21st Jan 2015, 04:54
