    Apr 2018
    brazil
    Hi guys!
    Recently I bought a TV box that makes recordings of channels, but when I went to try to access by the PC I see that it is apparently crypted, does anyone have a hint for me to get at least watch? Follow the recording file and the information in MediaInfo
    https://drive.google.com/open?id=1qTO5CjTcGaxOVEXjY82egz9R_WK7vGI5
    General
    Complete name               : C:\Users\juni7\Desktop\Pendrive\ALIDVRS2\[TS]2019-1-28.23.52.50-Nickelodeon HD-15\000.ts
    Format                      : MPEG-TS
    File size                   : 57.3 MiB
    Duration                    : 1 min 1 s
    Start time                  : UTC 2016-11-29 02:52:55
    End time                    : UTC 2016-11-29 02:53:53
    Overall bit rate mode       : Variable
    Overall bit rate            : 7 865 kb/s
    Network name                : Embratel
    Original network name       : Astra Satellite Network 19,2'E
    Country                     : BRA (1) / BRA (2) / BRA (3) / BRA (4) / BRA (5) / BRA (6)
    Timezone                    : -05:00:00 / -03:00:00 / -03:00:00 / -04:00:00 / -04:00:00 / -05:00:00
    Video
    Menu ID                     : 603 (0x25B)
    Format                      : AVC
    Format/Info                 : Advanced Video Codec
    Format version              : Version 2
    Format profile              : Main@L4
    Codec ID                    : 27
    Bit rate                    : 6 701 kb/s
    Maximum bit rate            : 9 045 kb/s
    Frame rate                  : 29.970 FPS
    Chroma subsampling          : 4:2:0
    Stream size                 : 48.8 MiB (85%)
    Encryption                  : Encrypted
    Audio #1
    Format                      : AC-3
    Format/Info                 : Audio Coding 3
    Codec ID                    : 6
    Bit rate                    : 384 kb/s
    Maximum bit rate            : 394 kb/s
    Channel(s)                  : 2 channels
    Sampling rate               : 48.0 kHz
    Compression mode            : Lossy
    Stream size                 : 2.80 MiB (5%)
    Language                    : Portuguese
    Audio #2
    Format                      : AC-3
    Codec ID                    : 6
    Bit rate                    : 384 kb/s
    Language                    : English
    Menu
    List                        : 1003 (0x3EB) (AVC) / 1001 (0x3E9) (AC-3, Portuguese) / 1002 (0x3EA) (AC-3, English)
    Language                    :  / Portuguese / English
    Service name                : Nickelodeon HD
    Service provider            : Nickelodeon HD
    Service type                : advanced codec HD digital television
    Maximum bit rate            : 9783600
  2. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    Cable and Sat TV being encrypted is the standard. Years ago, not every provider did this but I've not heard of any modern digital provider not encrypt the feed in recent years. At least you can pull the videos off the box and store them elsewhere, should the box fail. You'll have to get a new box. Some people have all their stuff locked to a single box.
    To actually copy the video to a computer, you'll have to either record the HDMI output or record the Component output. They don't make it easy.
