Hi to all. This italian live channel give the possibility to restart a program that is start before it's end.
https://www.mediasetplay.mediaset.it/diretta/rete4_cR4?restart
"https://restart3-mediaset-it.akamaized.net/Content/dash_d0_clr_vos/StartOver/Channel(name=r4,startTime=15490345140000000,endTim e=15490472890000000)/manifest.mpd?hdnts=st=1549038912~exp=1549053342~ac l=/Content/dash_d0_clr_vos/StartOver/Channel(name=r4,startTime=15490345140000000,endTim e=15490472890000000)*~hmac=e6d5d402f67a17a00ff68d5 6e15e969306f56f03a1f84207b3fde79d25030db5"
I used this tool:
streamlink "https://restart3-mediaset-it.akamaized.net/Content/dash_d0_clr_vos/StartOver/Channel(name=r4,startTime=15490345140000000,endTim e=15490472890000000)/manifest.mpd?hdnts=st=1549038912~exp=1549053342~ac l=/Content/dash_d0_clr_vos/StartOver/Channel(name=r4,startTime=15490345140000000,endTim e=15490472890000000)*~hmac=e6d5d402f67a17a00ff68d5 6e15e969306f56f03a1f84207b3fde79d25030db5" best -o r4-.mp4
it's start to rip but not the restart stream, it's rip the live stream........ but I dont need to rip the live stream. I need to rip the restart of a live program.
Someone can help me how to rip the restart stream? Thank you
Results 1 to 10 of 10
Not 100% what you are trying to achieve but you can add --hls-live-restart to your syntax to jump back to the start of a livestream if you have missed the start. Its a little hit and miss though depending on the stream type. I have had live sports streams jump back literally to the start point, and continuous news type streams jump back anything from 10 minutes to 2 hours.
streamlink --hls-live-restart "m3u8" best -o output.tsLast edited by codehound; 1st Feb 2019 at 14:08.
It would be impossible for Streamlink to restart the stream. It will take you back to either when it did actually start. Or somewhere between 'live' and the start.
On the web page of the channel, there's the function of restart the live stream.....the restart use the ink like you can see in my first post.
You can see the start and the end "name=r4,startTime=15490345140000000,endTim e=15490472890000000"
So I search, if exist a method to rip, the same stream that I see on the web page when I click "restart" -
Hi ,
Investigate in this way (?) .
Not sure it'll solve .Code:set "ua=Mozilla/5.0 (Linux; Android 5.1; en-US; Nexus 6 Build/LMY47Z)" wget -U "%ua%" --no-check-certificate -c -w 5 -t inf -S --limit-rate=40000000 --retry-connrefused "http://..." -O "stream.flv"
Cheers .JE SUIS CHARLIE !!! -
I doubt it will work but try setting the start time to 0. Otherwise, you might try looking through the page source for the actual start time.
Thank you to all of you for yours ideas. I solved. I change with "user agent switcher" the browser, and I use "android" so the page use android code.
With this new version of the web page i find a .m3u8 link with start and end, like .mpd link. I tried with streamlink with restart option and it work.
It rip the stream like when i press "restart" on the web page. Mission complete..... -
Is this still working?
I am trying to get URL from this site: https://www.grandefratello.mediaset.it/diretta/?live=B1
But I only get the Dash one.
I am searching the m3u8 Link.
Anyone that can help?
Thanks in anticipation
Auto start stream + recording
By Sapi3nti4 in forum Software PlayingReplies: 0Last Post: 8th May 2018, 03:57 -
Help with live stream
By christheradioguy in forum Video Streaming DownloadingReplies: 10Last Post: 5th Sep 2016, 13:59 -
Windows Live Movie Maker will not start
By ro2124 in forum Newbie / General discussionsReplies: 4Last Post: 6th Dec 2015, 11:59 -
How to rip live f4f stream? (help needed ASAP)
By Scavvy in forum Video Streaming DownloadingReplies: 2Last Post: 14th Apr 2015, 01:22 -
Would an ac router stream a pure bluray rip to a wdtv live gen 3?
By yoda313 in forum Video Streaming DownloadingReplies: 14Last Post: 27th Apr 2014, 13:17
