How can i extend/ change duration of multiple clips (background color, text and image) on sony vegas at once and automatically move other clips afterwards without losing the settings.
[Attachment 47955 - Click to enlarge]
Automatically moving other clips is via the Ripple setting. You can stretch or compress a bunch of clips by selecting them all and then ctrl-dragging the edge of one. But to change the cut length (like for motion clips), you have to find a script.
Help with adding same text properties to multiple clips (Sony Vegas)
By KiwiGaming in forum EditingReplies: 6Last Post: 19th Jun 2016, 06:10 -
How to Keep Multiple Audio Streams in Sony Vegas Pro 13 ?
By kwanami in forum EditingReplies: 10Last Post: 14th Oct 2015, 14:41 -
How to combine multiple clips with different field orders in Vegas
By virguloso in forum EditingReplies: 3Last Post: 16th Jul 2015, 10:40 -
How to match the color between clips in Sony Vegas ?
By kwanami in forum EditingReplies: 12Last Post: 2nd Jul 2015, 05:23 -
Sony Vegas, How do you change the clip length of multiple clips? Please hel
By Purplehayes in forum EditingReplies: 11Last Post: 30th Dec 2014, 06:19
