I have multiple Hi8/Digital8 camcorders and VCRs, and I'm looking for the best way to clean the heads. I've heard q-tips are scratch or pull the heads, alcohol will rust the heads, chamois swabs will break the heads, cleaning tapes smear dust around, what should I do. I have an old VHS cleaning cassette.
Results 1 to 14 of 14
Use 99 percent isopropyl alcohol, chamois swabs, and a very light touch. If that's too much trouble, use the cleaning cassette.
https://www.youtube.com/watch?v=1KCz59TCy8E
Like this? -
I've seen heads cleaned by a professional. He used cotton swabs but would NEVER touch the heads with them. He soaked them in isopropyl and used the swabs to dribble it over the heads.
Is Isopropanol 99% the correct thing ?
i didn't find any chamois sticks ..is chamois for car care ok ? should i wash them before use ?
and what about using a piece of paper like some do ?
and for the other parts along the tape path ? -
Hope this is okay. Instead of cluttering site with new thread. I recently got a 8MM player/recorder, it even has a built in tv, on eBay, and when I record stuff on brand new tapes, it has a lot of noise and jumpy. So I have a few questions. Please advise at your convenience.
1. If I go the cassette cleaner route, instead of opening up the device and cleanig with swabs, is there any distinction between a head cleaner tape made specifically for camcorders, versus one made specifically for players/decks? Most of these 8mm tape cleaners are advertised for camcordes. So I wonder if it's safe to play them in non-camcorders.
2. If I go the swab or foam route... Would something like this be safe? DSLR SWABS.
3. Lastly, in general, when I watch youtube tutorials, or read tutorials on how to clean head cleaners. Are all these advice basically the same for all video cassette playrs? For example, VHS vcr vs 8mm player. They both use the same type of head, right?
Thanks in advance! -
"Jumpy" is not dirty heads.
"Noise" often is not either.
Cleaning heads is far too often treated as a cure-all to treat whatever ails a deck. And, of course, usually fails to do anything. Worse yet, wrong cleaning methods just make matters worse.
Sensor swabs are fine. For years, I used extras that I had on hand. (I quit using on my cameras as often because I upgraded to the auto-cleaning models, which removed dust.)
These days, I do the copy paper method. Strip up an A4 or 8x11, fold into squares. Put 91% IPA on paper, press gently but firmly against heads, rotate. Remove, repeat, until paper clean. Not fibrous paper, not recycled. Literally standard white copy paper. I use the same 20 lb that I have in my printer, bought from Sam's or Walmart or Office Depot.
"Cleaner" tapes don't clean, but rather just move dirt around. Those were for low-knowledge consumers in the 80s/90s. Don't do that now.
Youtube has lots of idiots when it comes to videotapes. Don't do what they do.
Yes, cameras somewhat clean the same as VCRs.Want my help? Ask here! (not via PM!)
Hi8 Camcorder, 2 Heads vs 4 Heads, What's Your Opinion.
By dellsam34 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 11th Jan 2018, 22:41 -
Found a new way to clean those small mini DV video heads.
By digicube in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 15th Feb 2017, 21:10 -
I need some help converting my old VHS, VHS-C, and 8mm/Hi8 tapes. Many Q's!
By CZbwoi in forum Capturing and VCRReplies: 80Last Post: 20th Apr 2016, 16:17 -
Need Help Choosing Capture Card, TBC, and Software/Settings for VHS/8mm VHS
By Duder_Me in forum Newbie / General discussionsReplies: 1Last Post: 25th Apr 2014, 10:47 -
By Duder_Me in forum Capturing and VCRReplies: 2Last Post: 25th Apr 2014, 09:42
