HI to all. I Found the this m3u8 stream:
http://vod02-mediaset-it.akamaized.net/farmunica/2018/10/262493_166340412c489c/hlsrc_s...hd_fp_mpl.m3u8
and in this you can see the AES key (download the m3u8 file and look on it)
I have tried with a lot tools but no one support AES, someone can help me?
This is the source of the stream:
https://www.mediasetplay.mediaset.it/video/icircuitidellamore/i-circuiti-dellamore_F309070501000104
Thank You
Youtube-dl should get it,since it supports mediaset.it site,but i get an error:
It is possible that it's because of geoblock (as i checked similar issues on github) and Italian VPN is needed. (to view it Italian proxy works fine)Code:C:\youtube-dl>youtube-dl "https://www.mediasetplay.mediaset.it/video/ icircuitidellamore/i-circuiti-dellamore_F309070501000104" [Mediaset] F309070501000104: Downloading JSON metadata [Mediaset] F309070501000104: Downloading MPEG4 SD SMIL data [Mediaset] F309070501000104: Downloading MPEG4 HD SMIL data ERROR: None of the available releases match the specified AssetType, Protection Scheme, and/or Format preferences
Adding --geo-bypass or --geo-bypass-country IT didn't help either.
If you're in Italy or if you are using Italian VPN you can try the code and see if it works or not:
If still not,maybe posting an issue on youtube-dl github will helpCode:youtube-dl "https://www.mediasetplay.mediaset.it/video/icircuitidellamore/i-circuiti-dellamore_F309070501000104"
Thank you for your answer. I am in italy. I heve tried with youtube-dl like you, and
it gave me the same error.... -
can somebody help me about this stream ?
By PrinzEugen in forum Video Streaming DownloadingReplies: 2Last Post: 16th Jul 2018, 00:36 -
Stream 0: audio first, then Stream 1: video PROBLEMS
By andwan0 in forum Newbie / General discussionsReplies: 5Last Post: 9th Dec 2016, 18:34 -
Issue with Yamb and MP4Box (adding audio-stream to video-stream)
By slax65 in forum Video ConversionReplies: 2Last Post: 21st May 2015, 06:39 -
Force RTMP stream over HDS stream
By pub in forum Video Streaming DownloadingReplies: 2Last Post: 24th Jan 2015, 15:45 -
what software can reencode an mjpeg stream on the fly and stream the result
By cjard in forum Video Streaming DownloadingReplies: 2Last Post: 30th Apr 2014, 05:22
