Is there ant adapter i can get for PC that can open the TV when it gets an hdmi signal from PC. At least something thar can be attained easily. I ser some obscure products here and there like this one
https://www.pulse-eight.com/p/104/usb-hdmi-cec-adapter
Results 1 to 13 of 13
The only means that I have heard of which allows HDMI CEC to be added to a PC is a Pulse-Eight HDMI adapter + KODI. CEC is implemented differently by different TV makers so it is necessary to run software which can be set up to emulate the CEC signals used by various TV brands.
There is little demand for CEC with a PC. HTPCs are far less popular than game systems, Blu-ray players, and audio receivers, all of which often have CEC built in. The Raspberry Pi 3 is supposed to have CEC available when using OSMC as its OS, but that is the only computer that has CEC built-in, as far as I know.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
I understand that there is little demand for this but i have a game pc and it would bw convenient if i had that function
The reason CEC isn't common for PCs is two-fold.
First, as discussed in this article: https://www.anandtech.com/show/5463/pulseeight-usb-cec-adapter-review, to work at the hardware level, it would have to be integrated into the video card.
Second, as discussed in this thread: https://www.avsforum.com/forum/26-home-theater-computers/2947560-adding-cec-turn-displ...idia-card.html, it's prone to communication errors between the numerous hardware manufacturers. So most, if not all video card manufacturers don't include CEC in their cards.
There was a recent thread where the OP was having an issue with his Blu-Ray Player turning off when switched off his TV. Turns out it was his Sony TV sending the wrong signal to his Panasonic player. He turned off CEC (Bravia Sync) on this TV and the issue was solved. -
In those cases where a PC needs to turn a TV on, the professional method has historically been to use a 9pin serial RS232 signal, or possibly an IR emulator+transmitter. This is true with both systems that are controlled by the core PC and those that are controlled by an AV controlling system (Crestron, Extron, AMX, etc).
CEC is improving, but it's still a joke.
<edit>More likely, IP or USB will become common control avenues for TVs.</edit>
ScottLast edited by Cornucopia; 30th Jan 2019 at 18:13.
Some of the technology mentioned in this 2010 article is outdated (firewire ports on TVs are long gone, and I don't think that RS232 ports are common anymore) but it explains some of what Scott is writing about.
I have seen Sony smart TVs which allow using an IR blaster attached to the TV's IR port or USB-port, but these are one-way (out) and allows the TV some control over a single device, like a cable box or audio receiver, with the TV's remote or keypad.
I don't recall seeing any TVs with an IR-in port, which would allow a PC to control the TV using a special cable with a connection resembling an audio jack on each end. You would have to use a USB IR receiver/IR blaster and IR blaster cable with a stick-on IR emitter to control a TV, which is less reliable than an IR-in port. (When I tried stick-on emitters to control a cable box, those sometimes came off.) ...and you would need software to control the IR blaster glued to the TV's IR sensor. Maybe Eventghost would work. However, I think that you might be disappointed with the results using IR to control the TV.
I don't know much about IP control and can't tell you if that is a possibility with any smart TVs other than some Sony models.Last edited by usually_quiet; 31st Jan 2019 at 12:59. Reason: clarity
I don't know and I don't have access to a Sony TV to try any software. Plus, there don't seem to be many PC apps for IP control of TVs at the moment. As far as testing your TV, I found some apps by typing "Sony Remote Control" in the search area at the Windows store, but I can't give you any tips on how to set up and use any of them.
Serial/rs232 is still on many current MOBOs. Just don't expect it on Macs or laptops.
Many TVs from Sony, Sharp, Samsung, LG have had serial control ins. Some new models still do.
Never said anything about Firewire.
ALWAYS read the manual about what control the TV supports. Usually, the mftr will also have links to utility apps.
Even if it's IR only, you can have a serial to IR converter box to stick an emitter right by where the TV's IR receiver is and control ANY tv that way. Heck, there's a whole industry involved in that, and every modern tv responds to IR.
Scott -
I only brought up Firewire because that was mentioned in the article I linked to. I wanted to make sure that option was eliminated from consideration since it is no longer viable.
There is also at least one USB IR receiver/IR blaster, the USB-UIRT, that enthusiasts use with EventGhost or Girder to control various devices. It isn't cheap, but it is very versatile.Ignore list: hello_hello, tried, TechLord, Snoopy329
HDMI-CEC on mobile phones?
By therock003 in forum Newbie / General discussionsReplies: 1Last Post: 13th Jun 2018, 18:32 -
ARC / CEC / AQUOS Link problems. Please help!
By Englischdude in forum DVB / IPTVReplies: 1Last Post: 11th Jan 2017, 14:34 -
2xHD camcorder HDMI out to HDMI in capture card (Thunderbolt)
By a1s2d3f4 in forum Capturing and VCRReplies: 17Last Post: 26th Jun 2015, 22:18 -
Picking out a video card...... is mini-HDMI as good as regular HDMI?
By True Colors in forum Newbie / General discussionsReplies: 7Last Post: 12th May 2014, 13:00 -
Looking for HDMI mux, or HDMI quad, where to find ?
By Kelte in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2014, 02:37
