I need to produce STL and SRT subtitles; some lines will have to be positioned at the top of the frame.
I understand formatting isn't possible for SRT, but what about STL ?
Can I set positioning in STL with Subtitle Edit 3.5.8 ?
If not, how else ?
Results 1 to 9 of 9
You can open the stl with Subtitle Edit, select the lines you want and choose the required alignment. You have 9 positions available.
You can also do it in srt, using the tags {\anX}, like explained here. -
Perfect, many thanks.
It looks however that VLC ignores the alignment instructions set by Subtitle Edit and saved as EBU/STL...correct ?
And saved as SRT results in nothing better (alignment code displayed instead of aligning the text as desired)
What would be another suitable popular subtitling format to use with Windows (Film & TV app) or VLC ? -
Del
Hi! I created stl file in SubtitleEdit-3.5.9 with Justification code centered text.
[Attachment 49658 - Click to enlarge]
But on Teletext level (888 page) on TV, i see always left position.
[Attachment 49659 - Click to enlarge]
Why it happens? Where can I apply the setting in SE?
MPC-HC subtitles at wrong position with 2160p movies
By BrechtB86 in forum Software PlayingReplies: 2Last Post: 10th Mar 2018, 11:21 -
Subtitles out of position
By charrua1 in forum Newbie / General discussionsReplies: 9Last Post: 5th Feb 2018, 11:22 -
.ts DVB with dvbsubtitles --> mkv with subtitles (wrong subtitle position)
By smellycat3 in forum Video ConversionReplies: 2Last Post: 27th Dec 2015, 17:45 -
How to edit a dvd's subtitle bitmaps color and position?
By Danny1 in forum SubtitleReplies: 10Last Post: 18th May 2015, 21:25 -
Customizing subtitles position and alignment when embedding SRT into MOV?
By Royy in forum SubtitleReplies: 3Last Post: 23rd Apr 2014, 09:27
