Hi All,
Not really sure how to define what is happening, so makes googling difficult.
We record a lot of TV, and watch it later. We also watch a lot of TV live, using Windows Media Centre.
When watching live, this effect is very minimal.
I've tried PotPlayer and MCE-BE, the latter doing a slightly better job.
So when there's a fast panning shot, or fast action, such as a cricket ball smashed for a four in the BBL (Hi to all the Aussies!), there seems to be an interlacing type effect, where there are actually 2 balls displayed, and it is very noticeable.
Now ... a two things changed at the same time, so not sure what may be causing this:
1) Upgraded from a 46" FHD TV to a 65" UHD TV
2) Decided to upgrade to a 4K@60Hz capable video card (RX550) from a quite old nVidia unit, even though we still run the HTPC at FHD.
Just wondering if this could be the video card, or just a setting in the playback software?
The TV tells me it's running in 1080p mode.
Any help or advice appreciated.
There can be several causes, just guessing:
- Your footage is interlaced and you watch it on a progressive monitor/TV without deinterlacing or bobbing
- Your footage is interlaced and your (poor) deinterlacer blends the fields
- The clip is poorly framerate converted at some point (e.g. PAL to NTSC)
Upload a sample so you might get better advice.
De-interlacing video
By CarloJ63 in forum Newbie / General discussionsReplies: 5Last Post: 4th Oct 2018, 10:29 -
Video artifacts - De-interlacing.
By shans in forum Video ConversionReplies: 20Last Post: 22nd Sep 2018, 09:50 -
Keep Interlacing while processing a video
By Marcoh_ in forum RestorationReplies: 10Last Post: 25th Jul 2016, 18:03 -
Avermedia Game Capture HD II showing interlacing artifacts on playback
By Fadedown in forum Capturing and VCRReplies: 6Last Post: 22nd Aug 2015, 17:57 -
Video Diagnosis - Interlacing Suspected...
By hizzy7 in forum RestorationReplies: 3Last Post: 5th Feb 2015, 22:30
