Hey guys, I have a Panasonic AG-1970 and it works great. I am running the S-Video into a Pinnacle 500-USB. Someone once said that the captures from Pinnacle's Studio software was horrendous. I decided to try to give VirtualDub a shot at the capturing process. When I am in preview mode (Before I even start to capture anything), Everything seems to look fine. As soon as I enter capture mode, for some reason the preview window shows the video twice, once stacked on top of eachother virtically, as if they are being smashed into eachother, and the resulting output file reflects that too. As soon as I stop the capture and go back into preview mode, everything is fine again. What can I possibly be doing wrong?
Share short uncompressed sample of such capture.
The only thing that comes to mind: it could be wrong alignment of chroma planes. -
I have to take a moment to grab some samples but this will show you what I mean....
[Attachment 47973 - Click to enlarge] -
The two fields are probably being stacked rather than woven. Check interlace settings.
Slow warped audio when capturing screen in VirtualDub
By GildedSpaceHydra in forum Capturing and VCRReplies: 0Last Post: 27th Dec 2018, 03:48 -
Virtualdub Capture: Inserted frame every 41st frame when capturing
By sventamyra in forum Capturing and VCRReplies: 14Last Post: 20th Apr 2016, 08:21 -
Blank Purple Screen When Capturing Webcam from VirtualDub
By aesthetic in forum Video Streaming DownloadingReplies: 4Last Post: 4th Sep 2014, 17:05 -
Capturing 1080i Virtualdub
By angelroj7 in forum Capturing and VCRReplies: 1Last Post: 16th Aug 2014, 06:33 -
Capturing 8MM with virtualdub - jagged lines in movement
By halpme in forum Capturing and VCRReplies: 3Last Post: 27th Jun 2014, 00:29
