AviSource("C:\Users\cherb\Desktop\babe.avi")
ConvertToYV12(last, interlaced=true)
MCTemporalDenoise(settings="low", edgeclean=true, ecrad=3, stabilize=true, maxr=2)
Trim(last, 2, 6051)
pretty basic script so far just trying to figure using MCTemporalDenoise. However, I cannot seem to get the correct set of plugins to make it function.
Script error: there is no function named "addgrainc"
(Grad2dbmod.v1.5.avsi, line 291)
(McTemporalDenoise.v1.4.20.avsi, line 1072, 1090)
Try DVDFab Video Downloader and rip Netflix video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
Results 1 to 30 of 31
http://avisynth.nl/index.php/AddGrainC
try doing a web search, this was the first hit in the results -
And AddGrainC is in the list of required filters for MCTD:
http://avisynth.nl/index.php/MCTemporalDenoise#Required_Filters -
https://drive.google.com/open?id=1eckxCQ4Ti0eeN6243J6LdWmyTlSoVbn7
Clip I'm working onLast edited by Cherbette; 29th Jan 2019 at 15:33.
Now I'm getting a there is no function named "Msuper" error. Lord why is it so hard to find all the CORRECT plugins to run a filter script.
Are you sure you have the right "bitness"? 32 bit filters for 32 bit AviSynth, 64 bitness for 64 bit AviSynth.
Try manually loading the filters within your script:
Code:LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\mvtools2.dll")
Make a script with only the following command:
Code:Version()
[Attachment 47935 - Click to enlarge]
On top is what I see with the version() script opened with 32 bit VirtualDub2, on the bottom is what I see when the script is opened with 64 bit VirtualDub.
The 32 bit AviSynth plugins folder on my system is:
Code:C:\Program Files (x86)\AviSynth\plugins
Code:C:\Program Files (x86)\AviSynth+\plugins64+
[Attachment 47936 - Click to enlarge]
Here's what happens when I do Version() -
When you download filters there's often an x86 folderand and x64 folder. You want the x86 version, not the x64 version.
http://avisynth.nl/index.php/MVTools#Filters
When I go to this page and download I only see one MVTools2.dll in the folder. It isn't divided into folders like some of the others. -
I just replaced MVTools in my plugins and now I'm back to there's no function called addgrainc lol. Do I need the addgrain.avs in my plugin folder as well? In the addgrain folder (downloaded from the link provided above) there is src folder, win32 folder with a addgrainc.dll in it and a win64 folder with addgrainc.dll and theres addgrain.avs. Currently the only thing in my plugin folder associated with addgrain is the win32 addgrainc.dll is this not correct?
the Win32 AddGrainC.dll is version v1.7.1
No. It's just a sample script showing how the filter is used.
That is correct.
Are you sure you have the right plugins folder? Some programs, like MeGUI, can use a private version of AviSynth. For example, MeGUI's private plugins folder is something like:
Code:C:\Program Files (x86)\megui\tools\avs\plugins
Possibly a conflicting plugin . Clean out your autoloading plugins folder. I'm guessing mvtools2 version
This would cause AddGrainC.dll to perform incorrectly? I've cleaned them out 2x already. This is my third attempt to get the CORRECT set of plugins. I think AddGrainC is the last one in the chain to load for MCTemporalDenoise? If so, wouldn't that mean that all other DLL's are correct?
No, this happens (I wouldn't say often, but when you have conflicting plugins it does). When avisynth loads plugins in the autoload directory upon initialization, there is an issue with some plugins. Even if you are using LoadPlugin() to specify another plugin when it load the list and comes across a bad plugin (usually the culprit is an outdated mvtools2 or masktools2) , that error , or something similar to it comes up
https://github.com/pinterf/mvtools/releases
https://github.com/pinterf/masktools/releases -
Also , if you use
Code:avsmeter avsinfo -l
https://www.videohelp.com/software/AVSMeter -
There is no function named "imagesource"
By leonsk in forum EditingReplies: 8Last Post: 30th Oct 2020, 08:19 -
qtgmc error "there is no function named removegrain"
By codemaster in forum Video ConversionReplies: 6Last Post: 17th Jun 2017, 14:51 -
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 08:21 -
AvsPomd: Script error: there is no function named "ffinfo"? pls help?
By mrdodoubler in forum Newbie / General discussionsReplies: 4Last Post: 28th Jul 2014, 06:17 -
Which are the free alternatives to VideoReDo's "QuickStream Fix" function?
By falco2000 in forum Newbie / General discussionsReplies: 4Last Post: 31st Mar 2014, 09:37
