Hi Just wondering is there any programmes or ways to download and keep shows from these sites Channel 4 and Channel 5
Closed Thread
Results 1 to 16 of 16
It's DRM protected, you can get separated audio and video files:
Audio
https://akadash0.akamaized.net/cenc/C5223450008/C5223450008A/20180103155822/22bcd29b-e...ASH_1500_a.mp4
Video
https://akadash0.akamaized.net/cenc/C5223450008/C5223450008A/20180103155822/22bcd29b-e...ASH_1500_v.mp4
But it's encrypted and you will need a key to decrypt it.
The links DO work, but both files are encrypted.
The content is protected which restricts unauthorised usage.
(DRM).
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : enca-40-2
Duration : 44 min 47 s
Bit rate mode : Variable
Bit rate : 96.0 kb/s
Maximum bit rate : 106 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 30.8 MiB (95%)
Language : English
Encryption : Encrypted
Do NOT talk about copying rented/subscription material
You are not allowed to rip/copy/record rented video. It includes streaming rented/subscribed video like netflix, itunes, hulu plus, etc.
From our rules:
Thread closedDo NOT talk about copying rented/subscription material
Moderator redwudz
Convert 6 Channel AAC to 6 Channel AC3
By TheRandomOne in forum AudioReplies: 18Last Post: 4th Jul 2017, 11:40 -
Downloading or Copying Video From History Channel?
By brispuss in forum Video Streaming DownloadingReplies: 23Last Post: 8th Jun 2017, 00:06 -
How to fix audio that jump from channel to channel?
By midts in forum AudioReplies: 2Last Post: 24th Apr 2017, 08:04 -
Premiere: Duplicate left audio channel to the right channel?
By ash_melb in forum EditingReplies: 7Last Post: 21st Oct 2015, 12:32 -
How to re-edit a single channel on DTS audio 6 channel
By maisawka in forum EditingReplies: 7Last Post: 26th Jun 2014, 11:55
