I have a folder of 81 HEVC videos with AAC 5.1 audio. I want the audio to be downmixed to stereo, keeping the bitrate and other parameters for the audio.
I know VidCoder can do it easily, but I've not been impressed with its audio handling. I keep getting a 'swishy' sound from it so I've just been doing passthrough then using AVIdemux to downmix one. at. a. time. But that adds even more work because I have to use MKVtoolnix to mux the subtitles and chapters back in that AVIdemux cannot be set to leave in, after using gMKVextract to extract then ASSTOSRT to convert the subtitles back to SRT because VidCoder cannot be set to NOT convert subtitles to ASS format.
Anyway...
Command line batch command for AVIdemux to just downmix audio to stereo? I'll just have to put up with having to mux the subtitles back in.
I would do this with ffmpeg and HRTF filter - works for me better than simple downmixing. You will need ffmpeg with sofalizer enabled and sofa file "dodeca_and_7channel_3DSL_HRTF.sofa" available in VLC pack for example (no need to install just search inside portable VLC)
Code:@setlocal @set FF=C:\FF @set PATH=%FF%;%PATH% @set faudio=%~1 @set aproc="aformat=channel_layouts=7.1,aresample=resampler=soxr:osr=48000:cutoff=0.99:dither_method=0,sofalizer=sofa=dodeca_and_7channel_3DSL_HRTF.sofa:gain=11:lfegain=9" @ffmpeg.exe -hide_banner -v 32 -stats -y -i "%faudio%" -c:v? copy -c:s? copy -c:d? copy -c:a libfdk_aac -b:a 128k -af %aproc% -f matroska "%~n1_.mkv" @endlocal
Don't have to use @ on every line. Just use @ECHO OFF at the start.
I do NOT want to resample, I want to just downmix to stereo, with AVIdemux, with a batch file. That works well enough for me because it doesn't muck up the sound quality. If I asked how to do the job with FFMPEG I wouldn't expect answers on how to do it with AVIdemux. :P
This is the project output I get from loading one video, setting the audio to LavAAC, filter to downmix to stereo. Can this be modified to load and process all videos in a folder one after the other? What if I replace the file name Video 01x01.mkv with *.mkv ? Will it load all of them and append them all together?
If not, what's the batch file equivalent? I see nothing in the command list on that page about audio mixing.
Code:#PY <- Needed to identify # #--automatically built-- adm = Avidemux() adm.loadVideo("G:/TV Shows/Show1/Video 01x01.mkv") adm.clearSegments() adm.addSegment(0, 0, 3637822708) adm.markerA = 0 adm.markerB = 3637822708 adm.videoCodec("Copy") adm.audioClearTracks() adm.setSourceTrackLanguage(0,"und") adm.audioAddTrack(0) adm.audioCodec(0, "LavAAC"); adm.audioSetMixer(0, "STEREO"); adm.audioSetDrc(0, 0) adm.audioSetShift(0, 0,0) adm.setContainer("MKV", "forceDisplayWidth=False", "displayWidth=1280", "displayAspectRatio=0") -
Finally found how to batch the job with this py file
run by this batch fileCode:#PY <- Needed to identify # #--automatically built-- adm = Avidemux() adm.videoCodec("Copy") adm.audioClearTracks() adm.setSourceTrackLanguage(0,"Eng") adm.audioAddTrack(0) adm.audioCodec(0, "LavAAC"); adm.audioSetMixer(0, "STEREO"); adm.audioSetDrc(0, 0) adm.audioSetShift(0, 0,0) adm.setContainer("MKV", "forceDisplayWidth=False", "displayWidth=1280")
But alas, AVIdemux make utter hash out of the audio, lowers the pitch and throws in a syncopated pulsing. I tried it just doing one file with the GUI, changing only the codec to AAC (LAV) and checking the box to downmix to stereo. Same garbage out. Also tried AAC (FDK) and Opus. All three have exactly the same garbage output from these videos. The space savings will be quite a bit IF there's a way to make it do the downmix properly.Code:set avidemux="C:\Program Files\Avidemux 2.7 - 64 bits\avidemux_cli.exe" for %%f in (*.mkv) do %avidemux% --load "%%f" --run fbx.py --save "%%f.mkv" --quit
Audio info from MediaInfo
video infoCode:ID : 2 Format : AAC LC SBR Format/Info : Advanced Audio Codec Low Complexity with Spectral Band Replication Commercial name : HE-AAC Format settings : NBC Codec ID : A_AAC-5 Duration : 43 min 15 s Channel(s) : 6 channels Channel layout : C L R Ls Rs LFE Sampling rate : 48.0 kHz Frame rate : 23.438 FPS (2048 SPF) Compression mode : Lossy Delay relative to video : -105 ms Title : Surround Language : English Default : Yes Forced : No
Code:ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L4@Main Codec ID : V_MPEGH/ISO/HEVC Duration : 43 min 15 s Width : 1 280 pixels Height : 718 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Writing library : x265 1.8:[Windows][GCC 4.9.0][64 bit] 8bit Encoding settings : wpp / ctu=64 / min-cu-size=8 / max-tu-size=32 / tu-intra-depth=3 / tu-inter-depth=3 / me=3 / subme=4 / merange=57 / no-rect / no-amp / max-merge=4 / temporal-mvp / no-early-skip / rdpenalty=0 / no-tskip / no-tskip-fast / strong-intra-smoothing / no-lossless / no-cu-lossless / no-constrained-intra / no-fast-intra / open-gop / no-temporal-layers / interlace=0 / keyint=240 / min-keyint=24 / scenecut=40 / rc-lookahead=40 / lookahead-slices=0 / bframes=8 / bframe-bias=0 / b-adapt=2 / ref=5 / limit-refs=0 / weightp / weightb / aq-mode=1 / qg-size=32 / aq-strength=1.00 / cbqpoffs=0 / crqpoffs=0 / rd=6 / psy-rd=0.30 / rdoq-level=2 / psy-rdoq=1.00 / signhide / deblock / sao / no-sao-non-deblock / b-pyramid / cutree / rc=crf / crf=24.0 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / ipratio=1.40 / pbratio=1.30 Default : Yes Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709
Downmixing AAC 6 channel to stereo with dialogue audio gain?
By vonsworld in forum AudioReplies: 4Last Post: 6th Dec 2016, 03:27 -
stream/copy video from media player to a file(since I get CRC if copying)?
By charlieship in forum Video Streaming DownloadingReplies: 9Last Post: 25th Jul 2016, 11:24 -
Possible incorrect audio downmixing (MPC-HC)
By asw3 in forum Software PlayingReplies: 3Last Post: 14th Feb 2016, 04:27 -
Issue with Yamb and MP4Box (adding audio-stream to video-stream)
By slax65 in forum Video ConversionReplies: 2Last Post: 21st May 2015, 06:39 -
Surround channel downmixing to stereo in movie rips - why?
By smokeluvr1971 in forum AudioReplies: 5Last Post: 14th May 2014, 19:30
