I need to create a 1080p video with Prores in MOV using ffmpeg. I can do that but I can't figure out how to specify the color matrix.
For example, I have a source video for which MediaInfo reports:
But after I encode (input is an AviSynth script) with:Code:Video ID : 9 Format : ProRes Format version : Version 0 Format profile : 422 HQ Codec ID : apch Duration : 3 min 23 s Bit rate mode : Variable Bit rate : 218 Mb/s Width : 1 920 pixels Clean aperture width : 1 888 pixels Height : 1 080 pixels Clean aperture height : 1 062 pixels Display aspect ratio : 16:9 Clean aperture display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 29.970 (30000/1001) FPS Color space : YUV Chroma subsampling : 4:2:2 Scan type : Progressive Bits/(Pixel*Frame) : 3.509 Stream size : 5.17 GiB (96%) Writing library : aja1 Language : English Encoded date : UTC 2019-01-07 01:43:55 Tagged date : UTC 2019-01-07 01:43:55 Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 matrix_coefficients_Original : BT.709
MediaInfo reports:Code:ffmpeg -i %1 -vcodec prores -profile:v 3 -quant_mat -1 -pix_fmt yuv422p10le "%~dpn1.mov"
Does anybody know how to force the Color Primaries, Transfer Characteristics, and Matrix Coefficients to BT.709? I guess I'm looking for something like "-x264opts colorprim=bt709:transfer=bt709:colormatrix=bt709" but for Prores, not x264. I don't see anything like this in the private Prores options:Code:Video ID : 1 Format : ProRes Format version : Version 0 Format profile : 422 HQ Codec ID : apch Duration : 3 min 23 s Bit rate mode : Variable Bit rate : 330 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 29.970 (30000/1001) FPS Color space : YUV Chroma subsampling : 4:2:2 Scan type : Progressive Bits/(Pixel*Frame) : 5.310 Stream size : 7.82 GiB (99%) Writing library : fmpg Language : English Matrix coefficients : BT.601
https://ffmpeg.org/ffmpeg-codecs.html#Private-Options-for-prores_002dks
Results 1 to 14 of 14
-vf zscale=matrixin=709:matrix=709:transferin=709:transfer=709:primariesin=709:primaries=709
Doubt if there any private codec option, you can try to flag this trough general commands:
Beware - seem there are two different prores implementations, plain prores is quite limited:Code:-color_primaries <int> ED.V..... color primaries (from 1 to INT_MAX) (default unknown) bt709 ED.V..... BT.709 unknown ED.V..... Unspecified bt470m ED.V..... BT.470 M bt470bg ED.V..... BT.470 BG smpte170m ED.V..... SMPTE 170 M smpte240m ED.V..... SMPTE 240 M film ED.V..... Film bt2020 ED.V..... BT.2020 smpte428 ED.V..... SMPTE 428-1 smpte428_1 ED.V..... SMPTE 428-1 smpte431 ED.V..... SMPTE 431-2 smpte432 ED.V..... SMPTE 422-1 jedec-p22 ED.V..... JEDEC P22 unspecified ED.V..... Unspecified -color_trc <int> ED.V..... color transfer characteristics (from 1 to INT_MAX) (default unknown) bt709 ED.V..... BT.709 unknown ED.V..... Unspecified gamma22 ED.V..... BT.470 M gamma28 ED.V..... BT.470 BG smpte170m ED.V..... SMPTE 170 M smpte240m ED.V..... SMPTE 240 M linear ED.V..... Linear log100 ED.V..... Log log316 ED.V..... Log square root iec61966-2-4 ED.V..... IEC 61966-2-4 bt1361e ED.V..... BT.1361 iec61966-2-1 ED.V..... IEC 61966-2-1 bt2020-10 ED.V..... BT.2020 - 10 bit bt2020-12 ED.V..... BT.2020 - 12 bit smpte2084 ED.V..... SMPTE 2084 smpte428 ED.V..... SMPTE 428-1 arib-std-b67 ED.V..... ARIB STD-B67 unspecified ED.V..... Unspecified log ED.V..... Log log_sqrt ED.V..... Log square root iec61966_2_4 ED.V..... IEC 61966-2-4 bt1361 ED.V..... BT.1361 iec61966_2_1 ED.V..... IEC 61966-2-1 bt2020_10bit ED.V..... BT.2020 - 10 bit bt2020_12bit ED.V..... BT.2020 - 12 bit smpte428_1 ED.V..... SMPTE 428-1 -colorspace <int> ED.V..... color space (from 0 to INT_MAX) (default unknown) rgb ED.V..... RGB bt709 ED.V..... BT.709 unknown ED.V..... Unspecified fcc ED.V..... FCC bt470bg ED.V..... BT.470 BG smpte170m ED.V..... SMPTE 170 M smpte240m ED.V..... SMPTE 240 M ycgco ED.V..... YCGCO bt2020nc ED.V..... BT.2020 NCL bt2020c ED.V..... BT.2020 CL smpte2085 ED.V..... SMPTE 2085 unspecified ED.V..... Unspecified ycocg ED.V..... YCGCO bt2020_ncl ED.V..... BT.2020 NCL bt2020_cl ED.V..... BT.2020 CL -color_range <int> ED.V..... color range (from 0 to INT_MAX) (default unknown) unknown ED.V..... Unspecified tv ED.V..... MPEG (219*2^(n-8)) pc ED.V..... JPEG (2^n-1) unspecified ED.V..... Unspecified mpeg ED.V..... MPEG (219*2^(n-8)) jpeg ED.V..... JPEG (2^n-1)
but prores_ks is:Code:Encoder prores [Apple ProRes]: General capabilities: threads intraonly Threading capabilities: frame Supported pixel formats: yuv422p10le yuv444p10le
Code:Encoder prores_ks [Apple ProRes (iCodec Pro)]: General capabilities: threads intraonly Threading capabilities: frame and slice Supported pixel formats: yuv422p10le yuv444p10le yuva444p10le ProRes encoder AVOptions: -mbs_per_slice <int> E..V..... macroblocks per slice (from 1 to 8) (default 8) -profile <int> E..V..... (from -1 to 5) (default auto) auto E..V..... proxy E..V..... lt E..V..... standard E..V..... hq E..V..... 4444 E..V..... 4444xq E..V..... -vendor <string> E..V..... vendor ID (default "Lavc") -bits_per_mb <int> E..V..... desired bits per macroblock (from 0 to 8192) (default 0) -quant_mat <int> E..V..... quantiser matrix (from -1 to 6) (default auto) auto E..V..... proxy E..V..... lt E..V..... standard E..V..... hq E..V..... default E..V..... -alpha_bits <int> E..V..... bits for alpha plane (from 0 to 16) (default 16)Last edited by pandy; 27th Jan 2019 at 15:50.
Hooray, that works! Thanks so much. A short test video:
Code:Video ID : 1 Format : ProRes Format version : Version 0 Format profile : 422 HQ Codec ID : apch Duration : 368 ms Bit rate mode : Constant Bit rate : 233 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 29.970 (30000/1001) FPS Color space : YUV Chroma subsampling : 4:2:2 Scan type : Progressive Bits/(Pixel*Frame) : 3.753 Stream size : 10.2 MiB (4%) Writing library : Lavc Language : English Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709
Thanks for pointing that out, I had missed it before. That probably explains why changing parameters like -quant_mat didn't make any difference before.
Thanks again guys. -
prores_ks produces higher quality , higher bitrates (than even Apple certified prores)
If you want to "spoof" the vendor writing library tag , add -vendor apl0 , and it will say "Writing library : Apple" , instead of Lavc, or fmpg . It increases compatibility in some programs -
if this is not required i would avoid video filtering section and try regular flag approach, not sure about zscale performance, probably ordinary scale can do same faster but once again i would try to avoid video filter.
If you can find a "regular flag approach" that actually works, you should mention it. "regular flag approach" doesn't work here.
If argument input = output, the zscale filter isn't actually applied or do anything to the video bitstream (it's a no-op) . If you check the differences with and without zscale, there are no differences. ie. It's all metadata
But for actual filtering, zscale is about 2x faster than swscale for typical operations, at least with Intel CPU's
Code:Performance "z" is optimized for Intel(R) Architecture and features faster processing times than industry standard swscale software. Time (ms) to resize FHD image to UHD with Lanczos filter. z.lib 2.8 swscale 4.0.2* Intel(R) Core(TM) i7-8565U 7.7 15.2 Intel(R) Xeon(R) Platinum 8176 10.8 22.2 Time (ms) to convert FHD BT.709 (YUV) to FHD BT.2020. z.lib 2.8 swscale 4.0.2** Intel(R) Core(TM) i7-8565U 8.3 17.5 Intel(R) Xeon(R) Platinum 8176 11.5 25.6 * scale=3840:2160:sws_flags=lanczos+accurate_rnd:sws_dither=none ** colorspace=all=bt2020:iall=bt709:format=yuv420p10
This is weird then... i made few tries with various configurations and indeed this doesn't work - it must be some serious regression in ffmpeg as there is no other way to control metadata without re-encoding... IMHO using vf (video filter) path is only workaround that may work if you decode and encode video but it will not work for plain copy (i know, not your case).
And remark about zscale - i was not aware that it is faster internal swscale and at the same time offer higher quality and new functionality not present in swscale. -
You can alter the metadata for prores afterwards with a bitstream filter. This will work with stream copy (not inplace edit)
https://ffmpeg.org/ffmpeg-bitstream-filters.html#prores_005fmetadata
But -bsf:v prores_metadata works for encoding too, this is probably a better way to do itCode:ffmpeg -i input.mov -c copy -bsf:v prores_metadata=color_primaries=bt709:color_trc=bt709:colorspace=bt709 output.mov
iirc prores_metadata was added end of October 2018, so depending on the age of your binary it's not surprising you build doesn't know the filter.
users currently on my ignore list: deadrats, Stears555, marcorocchini -
I use build from 8 November 2018 so seem it should be there... anyway it is quite strange that prores need to use separate bitstream filter where other codecs follow general commands... this is most annoying thing in ffmpeg - lack of systematic approach - everything depends on developer personal preferences not on standardization guidelines... ffmpeg could be really nice software if simple guidelines will be in use.
yeah, that's how ffmpeg is. :P
Another nice example is that with hevc_nvenc there are options named '-spatial_aq' and '-temporal_aq' where as for 'h264_nvenc' they are named '-spatial-aq' and '-temporal-aq' and those are just some of tons of examples like this all across ffmpeg and it's plugins, somewhere along the general evolution of the project codec standards got kind of twisted and not really understandable for non-ffmpeg-developers.
Assuming anything works similar to X in Y, even when X and Y seem similar usually goes wrong.
Pro side to this is that not too many developers get scared away by to strict coding standards and ffmpeg is still under active development unlike mplayer&mencoder.
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini
ffmpeg mp4 to bitmap to Prores
By chris319 in forum Video ConversionReplies: 90Last Post: 24th May 2018, 20:00 -
Convert Color Matrix of MOV File
By koberulz in forum Newbie / General discussionsReplies: 24Last Post: 8th Nov 2016, 20:41 -
Problem at efficiency of prores encoding vias ffmpeg.
By zhangjie in forum Newbie / General discussionsReplies: 0Last Post: 15th Jun 2015, 03:46 -
Strange ffmpeg error when ProRes encoding
By SameSelf in forum Video ConversionReplies: 8Last Post: 25th Aug 2014, 21:34 -
mpeg to prores 422 HQ Itunes spec with ffmpeg
By vinbel in forum ffmpegX general discussionReplies: 21Last Post: 29th Jan 2014, 03:07
